Interconnect advice appreciated
Posted by: Mr_Sukebe on 09 March 2003
I'm presently using a Chord Cobra between my non-Naim CDP and Nait 5.
Well it's time to get the credit card out and give it an upgrade.
The options appear to be either a Chord Chrysalis or a non-Chord alternative (of which I know of none).
Any recommendations?
Would the Chrysalis be a big improvement?
Posted on: 09 March 2003 by garyi
Mr Sukebe.
Put your wallet away or spend it on some music. You know it makes sense.
Posted on: 09 March 2003 by Mr_Sukebe
Gary,
Good advice mate, however, I already have close on 500 CDs and like to make best use of them.
Just found a useful site:
http://www.cheshireaudio.co.uk/Chord%20Company.htmThat seems to infer that the Cobra has now been replaced by Cobra 2 and that the next step up would be to the Solid.
Anyone compared the Solid?
Posted on: 09 March 2003 by bruce
Mr_Sukebe, I would follow Gary's advice but if you're intent on spending your hard earned, look in your Private Topics
No dogma my end Brian.
I have owned Nordost blue Heaven, Chord Anthem and normal stock leads, and I have never heard a difference.
I am off that band wagon now.
Posted on: 09 March 2003 by achandoke
Naim ARO. Thats the best cable for your application. Its tough to find, but I dont think there is a better cable out there that is used to connect Naim Gear to non Naim Gear.
