DacMagic + OpenSolaris
Posted by: {OdS} on 19 June 2009
This is a call to all the nerds around (non-nerds are still welcome though Winker)! Has anyone tried to use the DacMagic in Opensolaris? Or in any other alternative operating system? Thanks in advance!
Posted on: 25 June 2009 by {OdS}
I guess this topic can safely be closed and erasedWinker
Posted on: 25 June 2009 by PureHifi
Oh well - go on then....
I have only used it on Windows Vista and XP...
Biggest drawback is that the USB input on the DacMagic is limited to 48Khz...using a computer to output via optical or coax outputs should therefore be better.
Posted on: 27 June 2009 by {OdS}
Thanks for the info! Now I'll need to find a laptop with an optical output. And of course, hope that the soundcard works in Unix systems!
