N-Vi and voltage switching between countries
Posted by: JY on 13 December 2007
I am thinking of buying an N-Vi 220 - 240VAC. If I move to a 110V country, will I be able to switch the voltage without power supply change?
Posted on: 13 December 2007 by Manu
NO
Posted on: 14 December 2007 by JY
Manu thanks for your short and sweet answer.
If I cannot switch the amp voltage, generally would a step down transformer affect the sound quality?
Following up on the NO answer, what would it take to modify the N-Vi into a 220V machine? Would the parts change be so costly that I might as well buy another one?
Posted on: 14 December 2007 by David Dever
I could be wrong on this, but I believe any warranty support for the power supply would disappear–each supply is designed and tested at its (more narrow) rated voltage (range), unlike many general-purpose SMPS designs where the input voltage is autoswitching across a wide 90-250VAC range.
Posted on: 14 December 2007 by AV@naim
You will need to speak directly with the factory on this one I'm afraid...
Effectivly its a new PSU.
Posted on: 30 December 2007 by rgame666
For me it is getting to the point where the lack of multi-voltage support in a product means I probably will not buy it.
Cheap $5 transformers do 100-240 volts - computers usually have a 110 or 220v switch on the back......how bloody difficult can this be???
Posted on: 30 December 2007 by Don Atkinson
Yep, rgame666, i'm with you on this one. Christ. I can even remember I used to have a Dansette record player that had a double-sided cartridge with a change-over lever for old 78rpm and the newer 45rpm records. It also allowed me to stack half a dozen records so I could have continuous music whilst bonking the latest girlfriend.
Why is it that technology keeps going backwards or that "specialist" hifi manufactures keep ripping us off by fitting single-purpose "specialist" pieces of kit at sky-high selling prices???
Don
Posted on: 30 December 2007 by David Dever
You're lucky–I remember the days of pro audio gear (typically made in the U.K.) for which there were no 115V transformers available for export markets.
