Listening to music at home can be an annoying mission …
Posted by: Arye_Gur on 29 April 2002
Feel free to add –
- I have to check every few days if the LP12 is leveled
- I have to notice if the disc is fully centered on the axle of the cdp
- I have to count the number of rubber rings on the pack
- I have to check the screw-nuts of the rack (especially if it is a Mana…)
- I have to check the direction of the fuses
- I have to push to many bottoms if I want to repeat one track on a cd
- I have to be aware to how good is the main electricity of the wall
- I have to check that the refrigerator is not on the same ring with the stereo
- I have to check that the equipment is hot enough – so leave it connected 24/7
- I have to check the weather forecast for lightning storms (see the former paragraph)
- I have to check the direction of the antenna …
- I have to learn how to clean the cdp transport surface
- I have to learn how to clean the panel
- I have to check the direction of the cover if I remove it
- I have to check the level of the cdp feet..
- I have to find out if a 72 sounds better without the TAPE circuit
- I have to find out if I can rest a PS closer than Naim’s recommendation
- I have to illuminate the 102 volume and balance knobs (why to bother for a 82?)
This is what I recall now, and my memory is short.
Arye
BTW – someone knows a good mini ???
Posted on: 29 April 2002 by Arye_Gur
Steve says
Choose the track you like.
Hit "Prog" button.
Hit "Play" button.
(Hit "Repeat" button.)
That's not hard!
Steve.
James thinks that it is too much.
Arye
Posted on: 29 April 2002 by Nigel Cavendish
i have to worry i have nothing to worry about
cheers
Nigel
