Direct from 200 to AV Processor?
Posted by: rock100 on 27 July 2010
Instead of using unity gain from a Naim preamplifier is it possible to just go direct from a Naim 200 amp to an AV processor to power the front two channels of a home theater system?
Posted on: 27 July 2010 by Richard Dane
Rock, I'm not entirely sure what you're proposing here. The processor has to come before the amp. Unity gain allows the preamp to fit between them so the amp can be used for 2 channel replay through the preamp as well as multi-channel replay through the processor.
Let us know what do you have and what are you trying to achieve and we'll try and make a recommendation.
Posted on: 27 July 2010 by rock100
Hi Richard
I have separate 2-channel and AV setups in different rooms. My AV system has a non-Naim 5 channel amp and non-Naim 7 channel preamp/processor
I would like to connect a Naim amp to the front 2 channels of the AV system to improve the sound and to upgrade to 7 channels of amplification.
Since the AV system is dedicated the only use of a Naim preamp would be to use the unity gain AV connection to connect the Naim amp to the non-Naim HT preprocessor.
Is it possible to not use a Naim preamp and connect the Naim power amp directly to the HT processor?
Thanks much for your help
Posted on: 27 July 2010 by lawoftrust
Hi Rock100,
that is possible, you just need the proper cables to connect the Nap200 with your pre, however, as I understood it, Naim strongly recommends to use Naim power amps only with Naim Pres.
Richard will be much more capable than I to explain the hows and whys.
Georg
Georg
Georg is correct, it's mainly to do with allowing the power amplifier to operate within its bandwidth "comfort zone" to get the best from it. However, I'd imagine most processors will have some form of bandwidth limiting (i.e. limiting ultrasonic stuff over 40kHz) so I guess it'll be a case of try it and see. You'll need an RCA- 4pin DIN interconnect - I think Naim can supply a suitable cable here.
Posted on: 27 July 2010 by Former member
I wouldnt bother.Can off worms or mullet comes to mind.
Nothing is outputting in 7.1 anyway thats better than 5.1.
What make is the rest of your AV kit?
Stu
Stu
Hi Stu
I have a fairly recent Integra DTC 9 Pre amp and a Rotel 1575 amp..... Not real exciting but ok for Home Theater
Just for fun I plugged in My Nait XS from my 2 channel system using unity gain and it took the sound to a new level.
My thought was to get a Nap 155 or Nap 200 and run it directly to the Integra and try to get the same improvement.
I guess another question would be does the unity gain connection sound so good because the Naim preamp is not just passing the signal directly to the HT preamp but is it actively involved in affecting the sound?
Thanks again for all the responses.......
It sounds so good because you get the Naim Pre and power amps running the front speakers.
Its like the other stuff is not there if you get what i mean?
I went through all this after going from a n/VI to 122x/150x/Flatcap2x/cd5x.
Unity gain through one of my two top end Sony surround amps a few years back.
Just look on Naim Dealers sites and pick up a GOOD SH 122x or 202 and 200 and use the Unity Gain.
Best way to go at the end of the day imo.
I still get to hear my old Sony;s one round my sister inlaws and one round a good mates house who uses it with a 202/250 unity gain.
Stu
Stu
Posted on: 27 July 2010 by james n
Rock - i did this a few years back with an old system i had. Marantz surround processor into my normal 72/140 for the front channels, for the rear and centre i used a couple of Naim 90.3 amps running from the processor which worked fine with no issues. A company like Flashback cables can make up the RCA/DIN leads to your spec.
James
James
Posted on: 03 August 2010 by rock100
James
Per your suggestion, I bought the correct cable from Flashback and plugged in an old s/h 155xs I had, direct into my AV system. I now have beautiful Naim sound coming from the front channels.
To me, it almost sounds as good as when I had my Nait XS connected via Unity gain......
Thanks for your help
Posted on: 03 August 2010 by james n
Posted on: 29 August 2010 by Stuart M
Did the same with a Yamaha DSP-E800 using a NAP140 for rears and another for centre (1 channel only) worked great until I lost a rear channel on the DSP-E800 and so invested in an AV2.
Posted on: 31 August 2010 by David Dever
This is exactly what happens in AV bypass mode on a Naim preamplifier–if you are not using the preamp for any two-channels sources, then eliminate the extra box.
No bandwidth limiting or signal conditioning takes place, inasmuch is there is no active circuitry between the input and output socket.
Posted on: 31 August 2010 by rock100
Thanks David, it does work fine.....
I now have the best of both worlds - the 155xs makes a big improvement in my home theater system....
And no more listening to Disney movies thru my 282/200
