Quick connection question
Posted by: CraigP on 11 May 2003
Just a quick connection question from a relative newbie.
I have just aquired a Flatcap 2 to go with my existing CD5, 112/150 combo. I also have a headline 2 which is taking its power from the 112 (signal out B). I am now using the flatcap to power the CD5 and 112. I notice that there are additional outputs on the flatcap 2. Is it possible (and if so beneficial) to plug the headline in to the flatcap 2 as opposed to the 112??
Thanks in advance.
Craig
Thanks in advance.
Craig
