Can someone suggest a suitable mc cartridge for a linn axis with basik arm. Ive heard that the basik isnt really suited to moving coils however
The 72 Ive just acquired has 323/5 boards. Ideally I might change the arm at latter time when funds allow this. Any suggestions would be apreciated.
Posted on: 08 November 2002 by Laurie Saunders
How much are you prepared to spend?
Do remember the hierarchy rule.....it does work with a veangeance with record players. The "motor unit" (or turntable) is most important followed by the arm, then the cartridge. I know for a fact that a Michell Orbe with RB300 & £200 Ortophon MC25FL easily outperforms a Gyrodek (no QC) with SMEV and Ortophon Rohmann
I had a Gyro/RB300/MC25FL....the biggest upgrade came (after the QC) from changing the Gyro for an Orbe, the next biggest was replacing the RB300 with an SMEV, then the cartridge. I was able to try and compare all the above combinations because I bought the better kit before selling the older stuff
So my advice...get the best player(& PSU)you can afford before worrying about arms or cartridges.
Laurie S
