AV2 Small speaker setting cutoff frequency ?
Posted by: Roy Donaldson on 08 April 2005
Hi there,
Anyone know what the cutoff frequency is if I set speakers, primarily front and center, to the Small setting ? ie. below what frequency is then routed to the LFE channel ?
Thanks,
Roy.
Posted on: 08 April 2005 by Steve2701
This a now a variable figure with the latest firmware upgrade..
If you check page 21 of the DVD5 / AV2 manual you will find full instructions on this.
Basically you can set what figure you want to roll over the frequency from the fronts to the sub....
Posted on: 08 April 2005 by Roy Donaldson
So, the LFE frequency is what is set in the sub cutover frequency then ? Excellent. 80hz for me perhaps....
Posted on: 10 April 2005 by neil w
steve e mail me on
neil.g.w@btinternet.com
ive a couple of questions for you
neil
Posted on: 13 April 2005 by Steve2701
Neil,
Replied with both home & work e-mail a few days ago. Did you receive them?
