Tips for dedicated mains feed
Posted by: Harty601 on 19 October 2008
I am going to have a dedicated mains feed run in to my living room this week. Can anyone give any advice on cabling, power sockets etc to optimize performance???
Thanks,
Rich
Posted on: 19 October 2008 by 555
Hi Rich
This has been discussed many times, so well worth using the forum search function.
The Pukka Mains Spur Installation - Wow! thread is a good place to start.
Cheers - John
Posted on: 19 October 2008 by Harty601
Thanks John, will check it out now.
Posted on: 19 October 2008 by spacey
MK all the way and 10mm.sq flex. get a smaller (MK) seperate consumer unit fitted. simple as that.
Posted on: 19 October 2008 by HuwJ
I live in a new house so I don't really want to tear the place apart to put in new cables. Can you (a qualified electrician) convert a current cable run in to a dedicated spur without resorting to having to run new cables?
Thanks,
Huw
Posted on: 19 October 2008 by KTMax
That depends on the installation in your house but not likely... Roll Eyes
Richard.
Posted on: 20 October 2008 by Pussycat
HuwJ,
A dedicated mains radial circuit (often called a 'spur') is just that: dedicated from meter to equipment. Thus there's no way I can think of that an existing ring mains circuit can do the two jobs.
As r-tee says, ideally you should have 10mm twin & earth (but 6 would be better than nothing) going to a consumer unit with 32 amp RCBOs (a combination of earth trip and fuse) for safety and sound quality.
Again, ideally, you should try for one cable per piece of kit with separate RCBOs. However, any variation on the above is better than ring mains.
