What's wrong with subs?
Posted by: Rockingdoc on 05 January 2004
Being a fanatical purist type (why I else would I be here), I've previously avoided sub-woofer's like the plague.
Anyhoo, for our New Year's Eve house party, I decided to beef up the sound to suit the teenagers dance music and borrowed a sub. Nothing sophisticated, just a nice 15" driver in a ported 100 litre cab, 200 watt amp and a crude bypass filter.
It sounded great for the party, pictures were shaken from the walls, and everyone said nice things about the system.
The problem now is that my system sounds anaemic and bass light. We do have a big room, and I think I want a sub.
Can anyone advise of likely difficulties, will I get fed up with a sub? What should I buy, always REL?
The problem
Posted on: 05 January 2004 by Tarquin Maynard - Portly
Doc
I have heard a Linn sub in a Linn system. Sounded fantastic and had far more effect than simply increasing the audible base lines. ( how weird is that? )
I understand that Naim are going to launch one which says it all, really.
Mike
On the Yellow Brick Road and Happy
Posted on: 05 January 2004 by Edouard
"The main problem with subs is integration. Some people succeed, but most fail, to get a seamless blend between their main loudspeakers and the sub."
The new KEF Reference 207 (8999£) come with the PSW5000 Active Sub-woofer (4000£). See the HiFi+ 2003 Sept-Oct issue. I have not listen to them, but they rated them really high,saying that those speakers performance challenges speakers that are far more fashionable and cost many time as much!
Edouard
Posted on: 05 January 2004 by Jason Milner
... which is one of the reasons why REL score so well - their subs tend to offer far more control over the various integration parameters than most. They also have some useful info on subs in general (with a slight, but forgiveable REL bias) here.
That said, I'm running a Sonus Faber (Gravis) myself, but then I also use their Speakers, so I went for the one make approach.
J
Posted on: 06 January 2004 by faz
Naim to release a Sub?
When?
How much?
Will it work with old Naim eqpt?
Please tell.
Posted on: 06 January 2004 by Rockingdoc
Many thanks for the advice so far. I'm particularly indebted to Andrew for his new word for a wife "spuse" which I shall use at every opportunity
Originally posted by Andrew B.:
a lot cheaper and more spuse-friendly too.Andrew
The next sub question being; is biggest (i.e. most expensive) always best? I'm disappointed that most hi-fi subs use only a 10" driver, as coming from a rock-bass background I've always believed there is no substitute for driver inches. I used to play through a pair of 18s when I was a boy.
Posted on: 06 January 2004 by Rasher
Curious Doc.
You see, you ask the question with a bit of suspicion that this may be a red-herring, get a reasonable answer, and then come back saying you don't think less than an 18" driver is enough. I know what you mean, but you are obvously intent on doing the extreme bass thing which is going to end in disaster. Makes me think you don't know what you want.
Are you sure you don't just need to get a PA thing for parties and dance music, and leave the main system alone for the "serious" listening that HiFi is all about? You may end up with a system that doesn't satisfy either way. Andrew has obviously found a way to enhance his system, not change it into a PA. I think you are coming at it from the wrong angle.
Interested to see how this pans out.
Posted on: 06 January 2004 by i am simon 2
I got a REL Quake for my birthday from my other half . You must admire her taste in gifts.
I wanted it mainly for the HT setup, but thouth I ought to try it on the hifi, 42.5, 10 driving royd minstrels - small ported floorstanders...Using the high level output from the speaker terminals rather than the amp as discused elseware.
At first you want to justify its existance leaving it turned up quite high with a high cross over point. I then decide it was too boomy and obvious so I turned it down and down in volume and crossover point.
This was better but then I still decided it was boomy. So i reversed the phase with the switch on the back of the rel. At first I thought that this was no good as it seemed to be so quiet, it must be canceling out all the bass responce from the royds. Then after a few minutes of tweaking the cross over and gain control it began to work properly, and with the phase reversed it seemed to no longer sound bloated and tightened up no end. Perhaps the revesed phase helps to cancel some of the ported minstrel peak just above the crossover point giving a smoother transition and flatter responce.
I am now crossing over at about 35 hz and the gain is at about 25%. In theory with these settings the sub is doing very litle, but bearing in mind it is only supposed to cover such a small (but important ) part of the spectrum it does make a lot of diference.
Whilst I have not auditioned the larger Rel's (to exspensive) the quake, which is tiny in size does more than enough in my medium sized listening room (18 feet by 12 feet).
So far I have not used spikes under the sub, as rel do not recomend this, however on its own feet it started mooving around on its own on the wood floor so I have blue taked it in place which seems to work well. What have other people done with their sub-floor inerface?
Simon
Posted on: 06 January 2004 by Geoff P
Andrew & Simon
FYI I have a REL Quake. I got fed up with it moving around so I put the spikes in the feet. In my case this was a accidental success story.
Lifting the sub off the floor that couple of inches made the Bass output a little drier and a bit faster which fits well with the Naim sound.
Tweaking up the volume to compensate for the slight reduction in weight due to raising the downward firing sepaker away from the floor worked well aswell.
Maybe worth a try for you
GEOFF
Posted on: 06 January 2004 by Dev B
Andrew,
Good on you for trying a sub. I also have a good sized room which opens out into a large space and whatever anyone says the character of the bass changes in such an environment. It is good to hear that a sub can work with the ultra fast SBLs. A sub has been on my Naim wish list for a while (please Naim, I am sure you could do the mother of all subs), but in the meantime I am tempted to try a REL or a M&K to see what happens in my room.
I am a sub novice, how do you connect the sub to the speaker terminals, do you have to solder it or something.
regards
Dev
Posted on: 06 January 2004 by prowla
Hmmm - I'm going to have to try a sub in my system some time, just to see what the effect is.
My Kans can play a bass tune but I have to admit that they don't batter my kidneys. (Yuk - just had a vision of a chip-shop menu with battered kidneys!).
Problem is sub means extra amp, more wires, etc.
Paul Rowlands
Posted on: 07 January 2004 by Rasher
That truly is disgusting, but I bet someone somewhere.....Do people still eat offal?
I've seen cheap subs in Richer Sounds. How much do you need to spend to just try the effect?
Posted on: 07 January 2004 by Nime
PS. Paul, you don't need an extra amp for an active sub like the RELs (and you should avoid the passive ones).
A
I presume you mean cheap commercial passive subwoofers? I had great success with DIY coupled cavity passive subwoofers (using 10" Seas units) with my Kans.
Flat to 20Hz @ 100dB (-3dB at 16Hz) A bit big and massively heavy at 21" cubed (x2). They make good large pot plant stands for those with WAF worries.
I would agree that the coupled cavity subs might not suit floor standers that go much lower. None I've seen have a suitably low upper roll-off point.
Mine each had single 4" exit ports. Which certainly allowed non-turbulent flow compared with any normal speaker reflex port. Though I radiused the exit pipe rim for appearance I noted no difference.
Other than with Kans and similar sized boxes it is probably better to use good active subs. If you can afford two.
I still find it fascinating to hear that Mana stands, bigger amps and mains spurs can achieve subsonic bass from conventional speakers. Those who advocate such things have obviously never experienced really low bass. It may be that cleaning up the higher bass frequncies gives the impression that the bass goes deeper. Simply because the upper bass is no longer swamping the room quite so much as before.
The simplest test for your pet theories is to put on a good organ piece. What about a nice bit of Vierne? Can you feel anything but can't hear it? Thought not. 'Nuff said. Big Grin
Nime
Everyone has the right to be wrong.
Posted on: 07 January 2004 by Geoff P
Nime
I kinda agree with your theory. As I have gone from a non Naim CD/112/150 through various stages to where I am now with CDX2/282/SC/250mk2 on Fraim each addition including the Fraim has added more bass weight. The type of bass heard has also firmed up more. I have not changed my speakers throughout this but the way they portray bass is now percieved as deeper to the point that I am planning to stop using the REL sub I have, to fill in what was percieved intially incorrectly as missing bass performance.
I do still use the sub for home cinema and at low listening levesl where it still brings some benefit but at normal volume it is just not needed now.
GEOFF
Posted on: 07 January 2004 by Martin Payne
This was better but then I still decided it was boomy. So i reversed the phase with the switch on the back of the rel. ...with the phase reversed it seemed to no longer sound bloated and tightened up no end. Perhaps the revesed phase helps to cancel some of the ported minstrel peak just above the crossover point giving a smoother transition and flatter responce.
Simon,
one thing you need to know about ported speakers - the port extends the low-frequency extension of the speaker via a resonance, but below this point the acoustic output is reversed in phase.
By reversing the phase of the REL you have actually matched the phase with the bottom-end output of the speaker.
cheers, Martin
E-mail:- MartinPayne (at) Dial.Pipex.com. Put "Naim" in the title.
Posted on: 07 January 2004 by Rockingdoc
Mr Rasher, I think you are correct in thinking that I don't really know what I want. My active SBLs sound so weak in my big room that I have moved the Naim system to a small bedroom where they sound fine.
I am using some old Kef reference 104/3 things in the big room now but there is no bass, so I do want to beef up the sound, not just do fine tuning.
Posted on: 07 January 2004 by Matt F
Originally posted by James:
_When is a sub not a sub?_
With the exception of the RELs, I don't think many of the subs go much below 20 or 25Hz.
James
You are correct in saying that a lot of subs won’t go below 20Hz – certainly if you take room loading out of the equation and use a no more than –3dB figure. In fact of the REL subs only the Stentor & above will go below 20Hz under these conditions.
There are others that will go lower though – Velodynes new (digital drive) DD18 will play flat to 14Hz with no room loading – truly awesome – no REL can get anywhere near that. On top of this, the Velodyne achieves this with less than 1% distortion – this is truly astonishing as it’s not unusual for lesser subs to measure really high distortion (20-30%) when trying to produce deep bass at a decent volume. What these new DD subs also provide is inbuilt equalisation allowing the user to compensate for room characteristics.
I don’t work for Velodyne by the way but I used to own one of their lovely HGS15 subs (sold for financial reasons – sob) and this was superb with music. Again this was a “mega low” distortion sub which made integration so much easier i.e. there was no harmonic distortion to mess up the sound from the main speakers. That one would play flat (anechoic) to 18Hz.
Incidentally, if a sub has very low distortion then if you play a test tone of less than 20Hz through it you should not be able to hear a thing (but strange things may start happening to your room!) – if you can hear anything then the sub is producing harmonic distortions.
So, in concludion, subs can work really well in a stereo set up and yes of course look at REL (ST series preferably) but also consider MJ Acoustics (Ref 1 etc), M&K (MX push-pull models), B&W (ASW675 etc) and Velodyne (SPL series are a good place to start but if you can stretch to a DD model you won’t regret it and I will be most jealous).
Matt.
Andrew,
[QUOTE]To cite a couple of analogies; would you prefer to stir paint vigorously with a knitting needle or would you gently use a flat paddle? Does a highly strung 2-litre turbo feel the same as a big naturally aspirated V8 with identical power?
I think not ...
James
Excellent point and it's worth considering the area sizes of the various cones - you would need 3.5 8" drivers to equal the area of a 15" driver!
Matt.
Matt.
Purists should close their eyes...NOW!
My passive subs could (singly) give me bus travel sickness at (completely silent) low volume settings on a 30watt A&R A60 amp driven by an audio signal generator. There was still output at 7-8Hz and they were inaudible up to nearly 30hz when a soft sense of fluttering movement was just becoming audible as an airy purr. Below that they were completely silent. It was fun to walk the length of my 30ft listening room, down the open plan stairs and along the hallway with a low (just audible) tone on one subwoofer. You can really discover something about phase that way. I wonder why they say the A60 has bass roll-off? Smile
Not bad for 2 x 10" Seas units, a couple of sheets of 3/4 MDF, some PVC drainpipe and David Purton's £5 "Coupled Cavity Subwoofer" booklet. They won't go loud because they are perfectly matched to Kans at 87dB/Watt. I saw over 105dB maximum on test of a single subwoofer at 20Hz. I still have the graph of the tests somewhere. Flat line from 20hz upwards to the -3dB roll-off for the Kans.
The coupled cavity system pumps a port (or ports) often with the unit completely hidden inside. As are mine. The unit sits in a two cavity system with long connecting internal port and single 4" diameter exit port. This is a much more efficient way of moving air than any sized membrane you care to choose. It starts and it stops dead without overhang. It doesn't need hundreds or thousands of watts to reach only 25-30Hz. It's major drawback is finding a design that rolls off naturally & early enough, without using a crossover when used with larger speakers. It matches small speakers like Kans effortlessly & maintains the speed of the smaller speaker perfectly. As long as you use two of them close to the Kans.
The purists can open your eyes again now.
Nime
Posted on: 07 January 2004 by Johns Naim
Great thread
I'm a sub believer, that is in lieu of large expensive floorstanders that'll do a similar job of reaching down to infrasonics in the one box a-la DBL's etc.
My much loved SBL's do a more than reasonable job, as Naim quote they reach down to 30Hz in room, and I've got one review where they achieve 25hz at minus 6db in room - not bad for an 8 unit, no doubt helped by the close to the boundary placement. However, much has been made of the increased sense of ambience etc when the lower harmonics are correctly reproduced by a full bandwidth system, and as been pointed out, Pipe Organ and such, let alone HT sound effects go much lower than 25hz.
Hence, one needs the likes of DBL's,,,, or,,, a good sub IMHO.
Trouble is, I'm still waiting for Naim to produce something. Heh, it's on my 2004 wish list.
I'm curious as to how well the new/older Velodynes do on music. I've heard that they are supreme on HT, but not the most musical of subs - well at least that's what my Naim dealer tells me, but I've only heard one in a HT setup at a friends house - amazing, (HGS15) but I have no idea how they perform on music. Also, are the push pull M&K's as good as the velodynes, or better, or just different. I haven't heard any of them. They are available here, but trying to get a decent dem is like looking for a needle in a haystack, unless one is content to get a demo of explosions, car crashes etc via the ubiquitious HT.
Just curious.
Richard, are you reading this - we're all hanging out for a killer Naim sub.. Big Grin
Happy New Year to all
Best
John... Smile
Populist thinking exalts the simplistic and the ordinary
Posted on: 08 January 2004 by Matt F
John - I used to own a Velodyne HGS15 so I can speak from experience here. When I got it I was using a pair of KEF Ref 2-2's as main speakers - pretty good to around 35Hz in room.
Because I use an AV processor I was able to do some easy comparisons of the HGS15 against the Ref 2-2's - I could switch between the 2-2's on their own and then bring the sub in using an 80Hz roll off i.e. <80Hz to sub, >80Hz to KEF's. I was amazed at how much tighter/faster/cleaner the bass sounded when letting th HGS15 handle everything below 80Hz - sure I knew it would play deeper but the cleaness was amazing.
So, basically, the HGS15 played bass (below 80Hz) much cleaner than a not inexpensive (£1750) hifi speaker. This is down to the amazingly low distortion (which itself is down to great engineering - servo control and a massive 1250 watts RMS amplifier). Low distortion equals superb musical performance IMO.
The M&K push pulls are fine subs but they aren't in the same league as the Velodyne HGS's - the M&K's have the output but simply can't play as cleanly as the HGS's.
What's interesting to note here is that the new THX Ultra II specs for subwoofers require subs to produce 105dB at 20Hz with no more than 4% distortion. Hardly any subs have Ultra II certification and it's the very low distortion requirements that will trip them up - the Velodyne HGS15 and HGS18 both attained Ultra II certification.
Matt.
p.s. sorry to mention "THX" on this mainly hifi forum Big Grin
Posted on: 08 January 2004 by Nime
THX, HT & AV have all been mentioned as if somehow removed from music reproduction. The last I heard film music was very carefully recorded and most films do seem to have some. Does it really sound so awful on HT systems subwoofers and all?
Nime
Posted on: 08 January 2004 by Johns Naim
I guess the main reason for asking about how well the Velodynes and M&K's do on music, is to try and figure out how well they would integrate with my SBL's. As any SBL fan will no doubt be pleased to mention, they have tremendously tight, articulate, detailed, 'fast' bass, with little or no overhang or bloat. HT has music soundtracks, sure, but they mostly take a back seat to dialogue, effects etc, that being the main event and the music the add-on for emotional impact etc. Without the 'distraction' of video, ones audio senses become much more critical on music/HiFi IMHO.
My Naim dealer advocated the REL, which they stock, and in particular the Strata 111, being sealed, as the best/most likely match to an SBL. Apparently they have had the Velodynes in for test etc in the past, and sold a few, but generally didn't think they were as good as the REL's musically, i.e. for music reproduction purposes.
However, I find the Velodyne attractive because it is a sealed box design, (which should give excellent transient response) it goes VERY low in terms of extension (the bigger REL's will go there too, but they're ported designs albeit with some form of coupled cavity loading to 'tighten' the sound as I understand it) they have very low distortion coupled with high power handling, and er, they look nice in timber finish, and aren't a hugely excessive box re physical size.
The M&K appears to do well on spec, however the finish is not as appealing to me re being a plain painted black ash - THX 350 & 5000.
The thing that DOES attract me to the REL's is the way one can couple both high and line level outputs at the same time, hence it can be used for music to extend the range of the main speakers, and in HT mode, will extend the bass of the main left and right speakers, as well as providing LFE from the AV processor via the separate low level feed. Neat.
I'm not aware of being able to do that with the Veodyne or M&K's. Is it possible? It makes a lot of sense to me in terms of value for money to be able to use a sub with individual connections for both HiFi and HT, as well as augmenting the performance in both disciplines.
It's certainly a wiring/usuage scheme I find very attractive.
On specs though, the latest range of DD Velodynes look quite something - at least if their website is anything to go by.
As a large sealed box unit, but not excessively big physically, with a very extended and low distortion response, it is very appealing, with the caveats of how it could be wired re the flexibility of a REL, and how it would perform as a match with SBL's.
It's interesting that they still use sealed box designs, rather that the reflex ports of others.
Here in Melbourne, there is a fairly new company called Whise, which makes subs from smallish domestic, up to huge, and I mean HUGE professional units. The drivers, amps, cabinet work etc is all done/built locally, and they use a patented method of bass loading called PAM or parametric acoustic modelling. This has been developed in conjunction as I understand it with a professor at Monash University, and Dr Thiele of loudspeaker design fame.
Interestingly, the speaker is hidden inside the box; it appears that two internal labyrinths 'feed' the output from both the front, and rear of the driver, separately, and summing them at an output port. They claim vanishingly low distortion, very low response, and coupled with very high SPL output. I've heard them, and most impressive indeed, again, not having been able to compare them to anything else in an A/B situation, it's difficult to make objective comparitive judgements. The only drawback from my point of view is that the labyrinth does result in a very large box, and I'm not sure how they would compare to a sealed box re transient response etc. I mention them, not as a 'red herring' as it were, but out of curiousity - I wonder if some of our resident speaker gurus would like to take a look at the site, and make some comment on the technology, as I lack the technical knowledge to do so, but find the arguments for it quite persuasive. Apparently they are selling extremely well, and are fast becomming highly regarded on the US HiFi/HT scene.
Goodness, don't things get complicated sometimes - Heheh, so many choices, if ONLY Naim would bring out a killer sub that would be a perfect match to the rest of their speaker range, the problem could be solved Big Grin
Warmest Regards
John... Smile
Posted on: 09 January 2004 by count.d
Rockingdoc,
I have the Shahinian Obelisks which punch out an amazing bass. They give me the "kick" in the stomach that live music produces and I find this is a high percentage of the enjoyment. The Hawks were even better.
It seems that the speaker design you have is not producing the sound you want. Have you listened to the Shahinian range?
The problem I've heard with a separate sub in a set-up is that you can always hear the isolated sub doing it's job. If the separate sub/speaker set-up was manufactured by a company like Naim, maybe they would get it to sound correct.
Posted on: 09 January 2004 by Dev B
Originally posted by count.d:
Rockingdoc,
I haver heard Shahinians and wasn't really that impressed, they don't really do PRaT and have a ponderous bass.
Thanks Dev, I was begining to think I'd bought the wrong speakers.
