Nac 82 + second Hicap
Posted by: ted on 08 February 2003
I have a CDX,82,one recapped hicap and a 250. What are the benefits of adding a second (recapped and a great price) hicap? Or should I save my hundreds and get a XPS? Thanks Ted.
Posted on: 08 February 2003 by Laurie Saunders
The XPS will be a more significant upgrade in your system ,albeit at a grater price. A second hicap for your 82 is definitely worthwhile...and quite good vfm in terms of sound per £
Sorting your mains, if you have not already done so is incredible value for money (and enhances the improvements heard with an XPS or Hicap)
Laurie S
Posted on: 08 February 2003 by Bob Shedlock
Are both the Hi caps the same style, ie. chrome bumpers or olive faces? Some say mixing the two styles (different transformers) can mess up the sound. Then there is also saving your money towards a Super for the 82.
Still, at the end of the day, if the 'caps match and it's a good price (as you indicate), I wouldn't walk away from a low price/high value step up.
Posted on: 08 February 2003 by ted
The second hicap is chrome bumper style like my other hicap, both have been recapped by nana in the last two years. Thanks Ted.
Posted on: 08 February 2003 by Peter C
XPS for the CDX makes sense.
Don't bother with a second hicap for the 82, just save and get a supercap.
The 82 reveals just how good it really is with a supercap.
Posted on: 08 February 2003 by Martin Payne
The second HiCap is a nice boost for the 82, but the XPS is a really big jump.
If it was a straight choice, you would do the XPS now instead.
If you bought the HiCap, how much longer would you have to wait before you could get the XPS, too?
cheers, Martin
E-mail:- MartinPayne at Dial.Pipex.com
