subwoofer
Posted by: mexico on 08 March 2003
Hi!
I would like your oppinions or recommendation on this:
If I want to use a subwoofer on my 112/flatcap/150 is it possible to:
a) take a line level output from the flatcap
b) use the speaker level output from the 150
Posted on: 08 March 2003 by J.N.
Mexico
A 'tape-out' etc: is no good to you; as it's a fixed level.
The preferred way of doing it (by REL anyway) is to take a feed off the speaker outputs. This provides the correct varying level AND sends the same character of bass to the sub and the main speakers.
Posted on: 10 March 2003 by Richard Dane
Mexico,
for Naim systems we recommend you use one of the pre-amp outputs on the power supply, in this case your Flatcap2, and connect to the line-level input on your subwoofer.
Richard
Richard
Posted on: 10 March 2003 by mexico
Originally posted by Tom Alves:
What speakers are you intending to use it with?
Tom
Totem Staffs (small floorstanders from Canada)
Posted on: 10 March 2003 by Gunnar Jansson
Yes the Mani 2 is an excellent speaker but will the 150 be able to drive them properly?? Otherwise I´d second that. One of my favourite speakers.
regards Gunnar
regards Gunnar
Nice speakers. Are you going to use the Totem sub as well?
Cheeky question. why not trade up your Staffs & with the money for the Sub get the Mani 2? They go low enough
Tom
Tom,
Thanks for yuor advice.
Unfortunately Totem distribuitor in México has closed. My only options right now are B&W, Energy Veritas and Vandersteen Speakers and Subwoofers.
Carlos
Posted on: 10 March 2003 by Geoff P
Mexico
Do as suggested by Richard Dane. I tried to connect as REL recommend by using their high level input wired across the speaker outputs on the rear of the 150. It does not work well it introduced "noise" at the main speakers. I have a HiCap so it was easy to take a line level (what REL calls "low" level) output from one of the spare outlets on the back of that. It did need a cable with the right din socket on it but the dealers can get them made up.
I assume it works pretty much the same way for other makes of sub-woofer.
One comment. I ended up with a REL because it was the only one that had a genuine variable "cut off" frequency setting knob AND that I found sounded "musical" rather than just thump-thump. As commented in a recent article in HiFi Choice a lot of subs have to be set for their lowest frequency cut off and they still tend to overlap with the low frequencies coming from your main speakers (including bookshelves which often go down quite nicely to 50Hz and below). The problem with this is, because you have an overlap which you cannot adjust out you get a "boom" in the region where the sub is playing the same frequencies as are coming out of the main speakers.
So check it out before purchase if you can.
A comment for Gunnar
The 150 has no trouble driving the MANI 2's. I have a pair and if you set the input gain on the 112 input to fairly close to max you can get the speakers up to what I would call in room "loud" with the 150 volume at 12 oclock to 1 oclock (starting from 9 oclock)
GEOFFP
GEOFFP
Posted on: 10 March 2003 by Martin Payne
Originally posted by Richard Dane:
Mexico,
Richard,
why?
A friend of mine tried his REL this way (spare output socket on his SuperCap), but said that it had too detrimental an effect on the sound from his SBLs.
He was much happier taking an output from his power amps.
cheers, Martin
E-mail:- MartinPayne at Dial.Pipex.com
Posted on: 11 March 2003 by Max Bass
Mexico-
I have the identical Naim electronics as you (112/150, flatcap 2) with the addition of a hicap, and added a subwoffer to my ProAc tablette 50 signature bookshelf speakers.
The connections are as Richard Dane recommends. I had my most excellent dealer make up the din to RCA cable and cross over the 150 at the input to give a high pass to the main speakers.
The results are incredible. Percussion now has that percussive attack/slam that I had been missing. Bass guitar is extended and musical. AND, because your amp no longer has the task of driving some of the lower frequencies, an added unexpected benefit of improving/opening up the midrange!
Max
Max
Posted on: 11 March 2003 by Rob Doorack
Are you referring to sockets 2, 3, and 4 on the Flatcap 2? Does the 112's volume knob control the level on those sockets? Thanks for your help.
