DVD5 question
Posted by: DrMark on 15 July 2009
Does the DVD5 play both PAL & NTSC? Are they constrained by region codes depending on where it was bought?
Posted on: 15 July 2009 by Neill Ferguson
you would have been best posting this on the AV section tbh. In answer to your question yes it does.
Posted on: 15 July 2009 by Massimo Bertola
Hi,
yes to the first question and I'm not sure to the second.
Massimo
Posted on: 15 July 2009 by michael1702
yes to both - i bought mine here in austria.
p.s.: for the second question: google is your friend. ;-)
Posted on: 17 July 2009 by Massimo Bertola
Mark,
it was you...
Silly me. Winker
Max
