How to switch nDAC inputs remotely?
Posted by: AMA on 14 December 2010
Is there any chance to switch between nDAC inputs using standard NARCOM 4 remote ???
Posted on: 14 December 2010 by jerryct
7,8,9,0 for switching the DAC inputs with remote in "pre"
if you play from a usb stick then 7 track backward (hold is rewind), 8 track forward (hold is fast forward), 9 stop and 0 play/pause
but there is no key (at least i have not found it) to switch between dock and undock (thus changing from usb to spdif with the remote)
jerry
Posted on: 14 December 2010 by AMA
jerry, thanks! It worked.
Posted on: 14 December 2010 by Aleg
jerry
to switch between dock and undock use button "select" when firmware is in pre 65 version.
In version 65 (the version that enables to switch off display) this "select" button no longer works for dock/undock.
aleg
Posted on: 14 December 2010 by Naijeru
Hmm, that's a bad trade. I'll avoid the firmware update then.
