HDX vs NS03 ?
Posted by: nicolas7 on 26 January 2009
hello
what are a differences (sound,cable,price,...) between a Naim Audio HDX and Naim Net NS03 ?
Thanks .
Posted on: 26 January 2009 by Gordon McGlade
Hi
The sound quality of the HDX is vastly superior and you can add an external power supply, the NS-03 you can´t.
The HDX only has 1 analogue output, the NS-03 has 4. The NS-03 is slightly less expensive, about 300€.
So unless you need 4 analogue outputs the HDX is the obvious choice.
Gordon
Posted on: 26 January 2009 by nicolas7
The HDX are a better sound with a external power supply : it's just normal .
But without external power supply , it is again better ?
So yes , why ?
So yes , why ?
Because the DAC is so much better!
Posted on: 26 January 2009 by SC
I didn't think it was a case of the DAC being better - which incidentally is the same unit to be found in the Snait - so much as the treatment of the analogue out stages...?
Posted on: 27 January 2009 by Gordon McGlade
It´s not exactly the same DAC found in the Supernait.
Yes it is a case of the DAC/analogue output stages. They are not even similar in design nor construction!
By the way the DAC does not just refer to an IC, it is the complete analogue to digital conversion out stage.
Gordon
Posted on: 27 January 2009 by gary1 (US)
Yes Gordon, good comment. I think that most people in their discussion of the DAC are thinking of only the chip and not the complete output stage. A reason why I think there is much confusion about price/performance of these devices.
Posted on: 27 January 2009 by james n
Doubtful - a handful of components in the output stage aren't exactly expensive either. Price / performance of the complete device is the issue.
That's what I was implying
Posted on: 27 January 2009 by SC
Forgive me for my error, I was merely repeating what I had read in Connection.
“In terms of its separate internal elements, the HDX employs analogue output stages derived from the NAC 552 with relay switched RCA and DIN output options. The seven pole analogue filter stages are on a separate board. The DAC is the same Burr Brown component as used in the SUPERNAIT and sensitive circuit elements benefit from triple regulated power supplies..." - Gary Crocker, Connection Winter 08/09
Posted on: 28 January 2009 by Cjones
Apparently the HDX uses an entirely different audio board. Also the deal with the power supply.
I have wondered if the digital out sounds the same, as the audio card wouldn't really matter then.
Posted on: 29 January 2009 by David Dever
The HDX digital out does improve with the addition of an external power supply–and still sounds better than a stock NS01 / 02 / 03.
Posted on: 31 January 2009 by connon price
Dave, you mean that the dig.coax out of HDX without external PS sounds better than dig.coax out on the NS players? By some or a bunch?
Posted on: 01 February 2009 by David Dever
By some - depends on DAC, digital interconnect (type), system, grounding configuration, etc.
