NAP 135 Fans
Posted by: JosephR on 21 September 2001
Is this normal that only 1 unit's fans start up while the other doesn't ? Or must they always start up together ?
TIA
There's a good chance that they need servicing.
-=> Mike Hanson <=-
Since I have separated them out more with a good air gap between shelves this seems not to happen any more.
You could try swapping the amps around and see what happens then... using your current left amp for the right.
The load of your speakers has a significant effect on your 135 fans too.. when I was running Isobariks on them the fans worked much harder than they do with my current NBLs.
Mike mentioned a service... I recently had my amps serviced and the fans replaced. They run much quieter than the original ones.
I guess servicing is needed, as I just noticed that even at 9 o'clock, the fan on the upper one starts when heavy metal is played. No bad effects on the sound, though, and since it's heavy metal I don't hear the fans ... Originally, I thought it was just at high volumes, 3 o'clock for Holly Cole's "Jersey Girl" and Metallica's "Enter Sandman". Funny thing about the other one is that the fan doesn't even start at high volumes !
Searched and found some posts on the 135's fans ... looks like just an adjustment needed, hopefully ...
Possibly. Alternatively, it may just be a heavy metal fan. ![]()
--Jeremy
Inescapable conclusion: this forum is inescapable
