Hi Cap Connections
Posted by: Ronnie on 10 April 2002
I have a Hi Cap, 32.5 pre amp, 250 power amp just like to check which connection I should use. Looking from the front of the HiCap on the left has the 5 pin snaic pin 4, which should the 250 connect to pin 3 next to snaic or pin 2
Posted on: 10 April 2002 by Dr. Exotica
Ronnie - the 250 should be connected to the Hi-Cap via socket 2, with socket 4 being used for the 5 pin SNAIC to the 32-5.
Erik
