I'm looking for a Multi -Room System
Posted by: Blueknowz on 09 January 2010
So I can play different sources in different parts of the house any ideas?
Posted on: 09 January 2010 by Graham Russell
Sonos. Easy to set up and easy to use.
Posted on: 09 January 2010 by pcstockton
NaimNet
http://www.naimnet.com/
Posted on: 10 January 2010 by rich46
sonos is fool proven. only 16bit. iam using with ripnas and naimdac ,using optical the music is stunning.
only wish it could except hi def downloads
iphone app is free and very good
Posted on: 10 January 2010 by Jack
Squeezecentre - lots of options for installation, simple setup and control from iPhone/iTouch if required. The Touch receiver can do 24/96 if needed.
Posted on: 10 January 2010 by Michael Chare
If you have a NAS with a UPnP server you can store your music on it (in a lossless format such as flac) and then play it using devices such as the NaimUniti or UnitQute, or some of the Roberts radios. You can also store video which some TVs can play.
