How big a differerence between older and newer 82?
Posted by: rp on 13 December 2001
I had my 52 updated with the new boards and felt the gains worth the difference. Not as big as the gray snaic vs black snaic, and considerably more expensive. But an 'old model' 52 still beats the pants off a latest-model 82 in no uncertain fashion.
Ron
Dum spiro audio
Dum audio vivo
From an old 82 to a new 82 would a waste of money, if you want to make an improvement, try going to a 52 or upgrading your highcap to supercap first.
I have done the opposite. Swap my newer 82 for an older 82. No big difference but i put some money in my pocket in the trade for futur upgrade (well in fact to pay my past upgrade
). I'm able to live with the older one for the waiting time until i find a great deal on a 52.
Bernard Paquet
Steve
Older 82's, by the way, will have a cable tie around several wires above the volume/balance controls, which should be removed and the wires gently spread apart. Also, the volume control response can be adjusted with a screw above it to make it turn more slowly in response to the remote control. Earlier ones can be a little too responsive, making fine adjustment difficult.
From circa serial # 125*** onwards the 82s (and 52s) have a lower noise discrete circuit board for the volume/balance which gives a cleaner, sweeter and more dynamic sound. Although conversions/updates are possible, given their not inexpensive cost are not cost effective for the 82
Ron,
Can you be a little more specific about the cost, since I would probably have to find about £4.5k to upgrade my 82 to a 52, and I'd want a CDSII before that at another £4.5k. They'll be the entry level kit by the time I can afford them.
Ade
Ron,
Could you maybe tell us more about this "lower noise discrete circuit board for the volume/balance"? Did the upgrade concern a change of the volume/balance section or even the main boards?
Thanks!
Willem
