What's your voltage?
Posted by: BigH47 on 30 March 2006
Whilst checking on plug types and voltage for our short break to Egypt I spotted these items:-
Brazil has no standard voltage, different states have their own,either 127 or 220v.Japan has single voltage varying frequency.There are several other countries too.
If these things are still true how do companies like NAIM cope with it?
Howard
Posted on: 30 March 2006 by Martin D
varying frequency
blimey that would cause problems surely?
Posted on: 30 March 2006 by BigH47
That should read IF WE COULD BLOODY EDIT :
single voltage(220) at either 50 or 60Hz.
Howard
Posted on: 01 April 2006 by hi fi fo fum
Howard
They send all the gear to Japan 220 volt only the poor people live in 127 volt region and can't afford to buy the gear so it is not an issue Big Grin
Brazil has no Naim importer Winker
Posted on: 01 April 2006 by undertone
Japan uses 100v, 50Hz. Only country to use this config.
Posted on: 03 April 2006 by arf005
We use 3-phase 6.6Kv at 60Hz out here...... Razz
Posted on: 06 April 2006 by Carlos Chean
Hi BigH47, which part of Brazil did you visited? Yeah, you're right, down here in Sao Paulo it is 110V, the Northeast, for instance, is 220V, always 60hz. Cool
Posted on: 06 April 2006 by BigH47
Carlos I have not visited either Brazil or Japan. I was just quoting from a web site. I was not sure how up to date it was though.
Howard
