yellow lettering
Posted by: Carlos Chean on 23 May 2003
Hi,
I am planning to buy a second-hand NAC 32.5 but its lettering is yellow instead of white. Is it very common? I know that's only a cosmetic issue but is it easy to find a Naim power amp with the yellow lettering to match the preamp? Which is newer, the yellow or white lettering? Or were they randomly made? The serial number is #30502. Any advice will be appreciated. Thanks.
