External H/D format on a MAC
Posted by: BigH47 on 14 December 2008
I have a 500Gb Freeagent drive that I used on the MAC for the Time Machine it is now spare as I have a Time Capsule.
This drive is now not seen by our Win PCs and I want to reformat in FAT32 to use on for back ups on our other machines and any extra saves from the MAC.
Could some one talk me through using the MAC to reformat this?
First look seems to be use erase in Disk utility.
TIA.
Howard
Posted on: 14 December 2008 by BigH47
OK maybe I should have been more confident. I just followed the erase in Disc utility, and If I had looked further I would have seen I could choose the format type.
At least the PCs can now see the drive.
Posted on: 14 December 2008 by garyi
Indeed, disk utility will do all this.
Posted on: 14 December 2008 by jon h
better to use NTFS format. FAT32 is horribly horrible, and vastly less reliable. Something to think about if you are using it for backups...
re:NTFS
The MAC won't use it if I need it to will it?
Posted on: 14 December 2008 by NewNaimy
You need a tool on the mac to write the NTFS Format. Without it you can only see the NTFS HDs, can read from them but can not write on them. One possible tool comes from Paragon. I think it came with an issue of Macworld as a free tool, otherwise see the website of Paragon and check the latest version, it is somewhat around 30 Euro.
But the use of FAT32 should work as well. At least if you don“t copy a lot of small files on t.
Is there a way of having the H/D partitioned some for MAC the rest for PC NTFS?
Posted on: 20 December 2008 by NewNaimy
That should work. Just split the HD, but still (if you want to excange Data from the one world to the other) you need something like paragon to write on the WIN Partition.
Posted on: 20 December 2008 by Derek Wright
For a backup resource you need to keep it as simple as possible. Do not rely on special programs to enable it to be read - because there is a very good chance that when you need to recover from the drive you will have lost/forgotten etc that you need to use a special program etc. By definition you will have to do the recovery in an unplanned time frame and with the feeling of panic settling in on you as you fear that you have lost all those valuable pictures of your sacred family event.
Posted on: 20 December 2008 by garyi
If its just for backing up I would suggest just use it for the PC. You have the TC for the mac. I have a 500g connected to my extreme base station and 3 macs, and since april I still have 325gigs left. I really is not an issue.
