The AV2, as a DAC or stereo pre-amp?
Posted by: Mr_Sukebe on 06 October 2002
Can anyone comment from experience on how good the AV2 sounds when used as a DAC for stereo music, or a pre-amp?
On it's own, I'm rather loath to spend over 2k on an AV decoder.
However, the AV2 looks somewhat more enticing when you consider that it should also operate as a good stereo pre-amp and potentially as a DAC for CD.
So, if you have experience, can you comment on the following:
1. When used as a DAC on the back of a CD/DVD drive, how close does the sound get to say a CD5 or even CDX?
2. When used as a stereo pre-amp, how does it compare to a 112 or better?
Posted on: 06 October 2002 by pac
Mr. Sukebe,
You will get an idea on the AV2 vs. 112 comparison by going through some of the previous Forum posts.
As a starting point, typing AV2 into search produces about 3 pages of posts right now. Both Naim Admin & members report that the AV2 is not quite as good as the 112. However, they also make it clear that the AV2 is considered really quite good for stereo.
I'll let more experienced Forum members respond to your first question on the performance of the DAC of a generic CD/DVD player. But it probably would not be reasonable to expect CD5 or CDX performance levels. FWIW, some members have started to experiment with cheaper SACD and DVD players with some interesting results.
Posted on: 06 October 2002 by Mr_Sukebe
Pak>
I think you've got where I was coming from.
If the internal DAC got anywhere near the performance of say a CD5 when partnered with say a DVD player, really would be a cheap way to get good sound.
Posted on: 08 October 2002 by gusi
I'd be keen to hear the AV2 as a red-book CD decoder too.
I realise that jitter has been raised as an issue with external DACs in the past but since everyone is raving about the quality of DTS/AC3/Dolby Digital decoder in the AV2 the jitter problem may have been solved.
Or is everyone raving because we are comparing consumer quality with audiophile sound?
An AV2 would be much more affordable if I could trade in my CDX.
cheers
Gus
Posted on: 16 October 2002 by Mr_Sukebe
Any other thoughts on this question guys?
Could any say how the AV2 would compare to a CD5 when used as a DAC on the back of a DVD player?
For that matter, could anyone say (from experience) how good the AV2 is an analogue pre-amp when compared to a 112?
