n-vi update
Posted by: john R1 on 23 August 2006
has anyone got or tried the new updated firmware yet for the n-vi, and if so does it make any differance to the problems with the optical input, ?
Posted on: 23 August 2006 by Former member
hi john mine has not come in post yet. regards munch
Posted on: 23 August 2006 by AV@naim
munch, I will look in to it tommorow.
JohnR1, another forum member has installed it and suggests that it has cured his optical problem.
Posted on: 24 August 2006 by Frank Abela
Our shop n-Vi used to occasionally lock up or not want to come out of standby. Applying the latest code last week seems to have made it glitch-free.
Posted on: 24 August 2006 by john R1
frank, my n-vi has differant problems to yours, mine all seem connected to the optical input from my telewest tv-drive, similar to the problems with the optical feed from sky-hd, so not sure if it will help, am waiting to hear from my dealer, who said he would try out the update first
Posted on: 24 August 2006 by Paul Stephenson
munch, you told me you had no issues right now and would only use the disc if anything happened so I have noT posted yet, waiting for my disc copy!! I am only the boss you know!
will send soon, if this is a problem call me as before
Paul
Paul
munch don't upset the boss, i am also waiting for a fix for the dvd-audio glitch as well as the optical input bug
Posted on: 25 August 2006 by Former member
many thanks regards munchquote:Originally posted by Paul Stephenson:
Paul
