Transmission Line
Posted by: Muzza on 07 November 2001
I have heard many references to Transmission Line speakers, but not seen a document outling:
Their point of difference.
Weaknesses
Strengths
Relative cost to produce
I am sure someone can help me out
Posted on: 07 November 2001 by Mike Sae
Some amateur obervations and stereotypes-
Weaknesses
Difficult to implement properly
Difficult to get coherent, integrated sound
Complex cabinet internals therefore higher cost
Less sensitivity compared to ported box
Strengths
Deep, quick bass from a small driver and cabinet
Comparatively inert cabinet due to internal folds
More sensitivity compared to sealed box
Easier to place
More
Posted on: 08 November 2001 by NAIM-Collector
A correctly designed and constructed pair of TLS can sound very musical.
These speakers will judge harshly any amplifier that isn't capable of driving these units correctly.
I am currently using a pair of IMF RSPM with 2x135 - bass, 1x250 - mid and 1x250 hifh end.
The low frequency from a TLS is quite detailed and open.
Like any high defintion loud speaker they will sound ordinary when coupled to inferior or low powered amplifiers.
I also use active Isobaric and these have advantages over the TLS such as tight bass but the TLS extend lower and have more ambience.
It eventually comes down to how good the amplifier is and the type of bass performance you are prepared to compromise on.
Regards..
