Electrically speaking, what should I ask for in the new home?
Posted by: onlythat on 03 December 2003
What does one ask their electrician to install as far as mains go?
Is it a "20 amp dedicated line"?
I just want one outlet done for audio, as that's where it gets plugged in exclusively.
So I just need to ask for this outlet upgraded or do I need some kind of separate line to the house or what?
Thanks a lot,
david
PS-- I like my life and that's why I wont do it myself. Guaranteed crispy critter.
Posted on: 03 December 2003 by dave simpson
Hi David,
Tell your electrician you need *one* dedicated 15 or 20 amp line installed with X number of outlets (X = whatever quantity you need).
The "dedicated" portion (a term which he will be familiar with) simply means a new circuit breaker, AC line and outlet(s) which will supply no load other than the one intended (in this case "load" = your hifi). The new line will be connected at your existing main house breaker panel (assuming it is not full of breakers and/or reached max. rated capacity).
Also, if he asks, the new dedicated line's ground doesn't need to be "isolated". Simply connect the ground per National Code/your breaker box's existing configuration.
If you have any further questions I'd recommend contacting NANA direct. The staff at NANA have a lot of experience with optimizing the mains in the US.
hth,
dave
[This message was edited by dave simpson on THURSDAY 04 December 2003 at 02:36.]
Posted on: 03 December 2003 by Stevea
Sounds like the best approach is to have your own power station.
Amen bro'...but in the meantime this approach works best;-)
regards,
dave
Posted on: 03 December 2003 by kuma
I had two dedicated 20A mains with 12 gauge copper wire. One for power amps, the others for source components.
The cheapest upgrades one can make.
Posted on: 03 December 2003 by Manu
Even if you prefer the single line approach for your sistem, ask for 2 now. If you go into AV later, you will plug your video gears in the second one.
Emmanuel
All opinions are my own, and reflect those of the organisation i work for, even if not stipulated.
Posted on: 03 December 2003 by onlythat
Thanks so much for the advice. My hi-fi is INDEED "a load". But now it's gonna be connected right.
Now how much do you think it'd be to wire it all up with solid silver wire??
(Sorry-- wrong forum).
Posted on: 03 December 2003 by prowla
Should a turntable power supply be connected to a different mains feed too?
Paul Rowlands
Posted on: 04 December 2003 by jpk73
What do you think about these things? There is also a new power socket with silver wiring by
Phonosophie.
