How do you connect a Stageline to a NAC 52 with a HiCap?
Posted by: smiglass on 25 November 2002
I recently took the plunge and connected my P9 to the NAC 52 with a Stageline using the power from Socket 2. What an improvement over the internal boards! Better presence and improved bass and imaging. I also have a HiCap that I would like to use with the Stageline but, the only way to do this is to connect the 4 pin output from the HiCap to the BNC connectors on the preamp. Is there another way to do this using a 4pin to 5pin interconnect? Is there such a thing and where would you get one. Thanks for any help
Smiglass
Posted on: 25 November 2002 by MarkEJ
Presumably you do this in the same way as with any other preamp. Your tonearm leads plug into the StageLine. The DIN output on the StageLine connects to the HiCap (may be socket 4, can't remember) with a SNAIC5 (which also powers the StageLine), and the signal is passed to one of the 52's high-level inputs with another SNAIC, although you will probably need the special 4 to 5-pin version.
I own not a single item here -- this is pure speculation and I think I should get a free Prefix if I'm right...
Best;
Mark
(an imperfect
forum environment is
better than none)
Posted on: 25 November 2002 by J.N.
I ran my Stageline like this.
You need a special 4 pin to 5 pin 'lavender' interconnect (in addition to a standard 5 pin SNAIC) from your Naim dealer.
Posted on: 26 November 2002 by Bernard Paquet
Question?
Ii it better to run the stageline via a hicap to the 52 or to use the socket 2 and take the juice from the supercap???
Bernard Paquet
