iTunes video problems
Posted by: Bosh on 25 January 2009
I've spent a lot of time trying to get some video clips to play in the latest version of iTunes to no avail. I tried new conversions a some that I know played ok a couple of years ago on earlier versions of itunes including trying 4 different conversion programmes
It wasnt until I downloaded some video Podcasts for a 24hr coach journey that I found whilst these wont play on iTunes either they play OK on his Nano and my Video iPod. Uploaded the other videos and found they also work OK on the iPod
ANy suggestions? Is there a bug in iTunes or some simple video settings issue ?
Posted on: 25 January 2009 by garyi
Sadly you have failed to mention what you are running itunes on.
assuming its a PC I would suggest reinstalling quicktime (itunes needs quicktime for its components)
Posted on: 25 January 2009 by winkyincanada
"Sadly"? Smile
Yeah, try re-installing Quicktime and perhaps iTunes itself. On my mac, I also needed a thing called "flip4mac" to run WMVs.
Posted on: 25 January 2009 by Bosh
Thanks for the suggestions will try these, I am running XP service pack 2 on a PC. Wi
Posted on: 26 January 2009 by Bosh
Re-installed iTunes and Quicktime on but still no joy. Get a green background with flickering red diagonal lines
No problems at all on my 1.6GHz dual core laptop. Unfortunately all my 1500 cds and 500 albums including covers are on the PC
Is the PC just too slow (3GHz Pentium/500Mb ram) or is there a bug/setting issue
