stageline in a non-naim amp system
Posted by: Theo on 07 January 2004
Can I connect a stageline with a flatcap2 to a non-naim amp?
I cannot find the info in the manual.
Theo
Posted on: 07 January 2004 by Richard Dane
Hi Theo,
yes you can. Assuming the amp in question uses RCA phono input terminals then you will require a 4pin DIN - RCA interconnect to take the signal from the Flatcap2 to the amplifier. Your Naim dealer should be able to supply a suitable cable from the Chord Cable Company.
Richard
