Fraim Questions
Posted by: Paul B on 06 May 2001
- How does an LP12 perform on the Fraim?
- Can one successfully use a three-tier Fraim say with 52 - Supercap - 250 (in descending order) or will the proximity of the 52 to the Supercap or 250 be a problem thus requiring a second Fraim for the 52?
- What are the dimensions of the Fraim? It looks quite large (has this been posted elsewhere)?
It may take some time before information starts to filter through as it has in the other thread.
I certainly hope that Chris Koster will post his findings shortly and Dave Dever will continue to do so.
Paul
look under product/accessories/fraim.
in fact..
one of the figures even shows a lil extra on the top glass...praps a mana spirit level...
As indicated before, the photographs incorporating the Series 5 components make the Fraim seem slightly larger (taller) than it is in the flesh.
I would imagine that the usual placement concerns still apply regarding power supplies, though the spacing between supplies seems to be fine with the standard shelf spacing.
No, we haven't tried it with an LP12--we don't, I'm afraid, have one at the office anymore. Will let you know once I get my hands on taller-height spacers,
Dave Dever, NANA
I would not use the larger spaced level for source components. Single levels to desired height is best. We found 3 levels to perform best, lower levels unloaded when used as cd player or t/table support only.
"We found 3 levels to perform best, lower levels unloaded when used as cd player or t/table support only."
Are you saying here that if I want my LP12 and CDX to sound at their best I should locate each one on the top of a 3 level rack with the lower levels unloaded?
This is the best performance we have found to date, this applies to almost all racks we have tried. Space and finacial considerations will be the deciding factor. In my home system I will have the CDS and 52 head unit on one stand with a space between them.
After trawling the forum I lean towards doing the following, supportwise:
1. Buying Mana for LP12.
2. Buying single level Fraim for CDX
3. Using old Sound Org table with Base01 for Lingo and maybe napsc - do they interfere with each other?
4. Using 5 tier Sound Org Table (with Base01s) for 82, CDPS, 250, 250, 2 Hi-Caps in any recommended order.
Not sure how much of that config I'll be able to audition b4 purchase but it seems sensible and cost-effective.
Any comments?
Alex
Or could it be that the combined amplification of the system costs nearly 100 grand?
david ng
[This message was edited by David Ng on MONDAY 07 May 2001 at 14:34.]
so that I can put the cat on top!
Dave Dever, NANA
So my earlier quibbles pale as I consider what would be best for my system:
1. Use top of 3 level Fraim for CDX = 1100UKP
2. Use top and bottom of 3 level Fraim for LP12 + Lingo = 1100UKP
3. Use top, & bottom of 3 level Fraim (with space in between) for 82, CDPS = 1100UKP.
4. Use top and bottom of 3 level Fraim for 2 250s = 1100UKP
5. Use top and bottom of 3 level Fraim for 2 Hi-Caps = 1100UKP
WoW! - That's 5500UKP - and I still haven't put the NAPSC or the tape deck anywhere yet. ![]()
Not a small room combination
Derek W
There is a famous mortgage bank in Israel.
They like music and Naim, and they suggest mortgage with good terms for buying Fraim.
They take as a bail houses (like Mike's at the least ) or cars (no less than Mercedes 500).
Do you want their address ?
Seriously for a second, I found that the cost of Base star here in Israel is the same as the estimated price of the Fraim.
What do you think ? For my eyes, the Fraim is much
more beatiful than the Base.
Arye
System, LP12 etc, CDX/CDPS, 82/2HCs, 2 250s
I have been advised elsewhere in this forum to trade in Hi-caps and one 250 for a Supercap.
This would help the system and save £600 in Fraim - nice. The 135s may have to wait.
ps sold tape deck for £10 and gave away all tapes - another £300 saved!
Can you imagine how much money you can save if you will buy a mini system ?
If we will adopt the logic of the Mana fans,
(And they are known as logical persons), a mini system on a top of three shelves Naim with two unloaded first shelves will outperform your present system.
I'm affraid Naim will want to forget about the great new Fraim !
Paul, Paul and Paul, maybe you have to rethink about manufacturing the Friam ?
Arye ![]()
