CDX and Mana, just how important is it ?
Posted by: Ancient Mariner on 26 June 2003
After some helpful reply's from some of you, I have decided to go for either a CDX or a CD5/ HiCap. But I have heard the CDX will only really shine if on a Mana or Fraim support. Basicaly I have a strict budget of £1300 no more. That will buy me a S/H CDX. But it will be sat on my Sonus-systems 5 shelf support, there is no way I can afford to buy either Mana or Fraim.
So my point is will a CDX still out perform a CD5/HiCap in my system knowing its not going to be used with Mana or Fraim. I have heard the CDX is better but I have also heard it can be a bit too over exiting and will my system be more balanced and suited to a CD5/HiCap ?.
I will be using the CDX or CD5/HiCap with the following : NAC92/FlatCap/NAP90.3 , Linn Helix speakers with the Kustone stands and NACA5.
I am going to audition both with a home demonstration, but if any of you can shine some light on it for now I would be very greatful.
Ian Marsh
Ian Marsh
