AV LED Backlighting
Posted by: Occean on 02 October 2010
I am thinking of seting up some LED backlighting on my TV.
The Apollo light kits seem highly regarded on the AV forums. Has anyone had any experiences? I cannot decide if the will be great or just plain awful.....
Cheers Smile
Posted on: 02 October 2010 by garyi
Do you mean in terms of following the the action or just nice mood lighting?
I got a real of leds from china with controller for 60 quid, these hide behind the slightly raised panel wall that the TV sits in so it gives what ever colour glow you want. very effective but not connected to the TV in anyway.
Posted on: 02 October 2010 by Geoff P
I have a Philips 42" Ambilight on my wall. I turned off the ambilight function because I found it annoying, particularly during atmospheric film sequences in low room light. The lighter colors in particular white and yellow are the most distracting.
regards
Geoff
Posted on: 02 October 2010 by BigH47
I fail to see the point of them, other than it is another selling "feature".
Posted on: 03 October 2010 by Occean
Cheers guys for the feedback
garyi it seems your setup is exactly what I am looking at. Decided for £60 I will give it a go and if I hate it, straight back on ebay.
Posted on: 03 October 2010 by garyi
Occean did you get the 3M LED strip?
They really are very good. mine came with a remote controlled control unit which makes it flash or slowly change or sit on one colour. However I found the code was the same as some of my TVs so I just switch on when ever now.
One of the best purchases I have made in a long time was an LED tv they are sooo thin so I was able to create what is in effect a door on a wall with the TV and centre speaker set in (please excuse the shitness of these pictures):
And on the back side of my chintsy suede number is this little lot, notice the Wii, harddrive and mini are out of site, just how I like it:
The LED strip hids in a gap unless you bend your head like I have with the camera all you actually see is a glow in what ever colour you have chosen, they really are great.
Posted on: 29 October 2010 by Occean
Well I picked up a set of apollo strips from neon lights
4 led strips and a remote, full colour cycles etc etc. Great purchase Red Face)
Posted on: 06 November 2010 by Adrian F.
garyi: looks like someone made a finished product from your do-it-yourself wall-rack idea...
cinewall
Posted on: 07 November 2010 by Derek Wright
Only problem with the Cinewall is the terrible face ache one has after installing it as you have to smile or grin continuously while installing it.
However apart from that it looks very competent.
Posted on: 07 November 2010 by Adrian F.
derek: didn't watch the "film" on the website up to your hint... reminds me on jack nicholson as joker Winker
I also liked the magical cable routing! You stuff a new cable in the upper hole, and it automatically comes out at the right hole down in the mediabox.
Never saw a 1.1 surround system before. 1 ridiculously small center with 1 subwoofer. When I would place my Axent on that, it would probably rip the mediabox down...
Posted on: 07 November 2010 by garyi
Bastards, I will be onto them for my royalty.
Posted on: 08 November 2010 by rackkit
AS will all the DIY guys and their floating walls over on the AVF forums. Haha!
Posted on: 09 November 2010 by garyi
Never been there so it does not exist.
Posted on: 11 November 2010 by rackkit
Hmm...you sure?
