Speaker cable for AV rears
Posted by: Jez Quigley on 21 January 2004
I have a Yamaha E800 AV amp for centre (an old Yamaha centre spkr soon to be replaced) and Epos14s as rears, 135s power the front L&R Briks.
At present I have some 'bell wire' running to the Epos 14s (it was the only stuff I had to hand that was long enough). NACA5 is the natural partner for them of course, but as I can't get it under the floor I need something that will go under the carpet. So can anyone recommend some cable that:
1. Fits under the carpet
2. Is a good partner for the E800 & Epos14s
3. Is not expensive for a 12 metre pair
