Connecting a Linn Linto to a Naim NAC 82?
Posted by: Jaybar on 29 August 2003
Hi. How would you connect a Linn Linto to a NAC 82? What kind of Interconnect do you need? Do you need to remove the phon0 board from the NAC 82. I am posting this question for someone who has purchased my Linto and he is getting a Loud woosh sound. The Linto should be silent. I think his tonearm cable is terminated with a BNC and he is using a BNC->RCA Adapter, but I am not sure. Please help with suggestions.
Thanks,
Jay
Thanks in advance,
Jay
Posted on: 29 August 2003 by Jaybar
The person who purchased my Linto has the Linto plugged connected to the phono input of the NAC 82, with the Board still in place. That must be adding gain on top of gain! I don't know much about a Naim pre-amp, but I don't think that is right.
Jay
Problem Solved!
Posted on: 30 August 2003 by long-time-dead
WHat did you do ?
It would be useful posting your findings in case anyone else ever suffers the same problem.
Glad to hear you got it sorted !
Posted on: 30 August 2003 by Jaybar
He connected to the auxilliary input instead of the phono input
