Naim bananas
Posted by: Lightkeeper on 04 June 2002
Hi to all !
Yes, it's me again.
I have Naca5 terminated with some Monitor bananas, but would like to change to Naim (2 in 1) bananas. One thing is not clear to me...
How do you guys connect Naim bananas in amplifier, because cable can be connectedt to it only from up or down, not horizontal. So if I connect it from downside, it will be very though because of shelf anf if I connect it from up, it will look stupid. Anyway, what is correct?
Ozren
Posted on: 04 June 2002 by Arthur
Ozren,
I have the cable going down. You have to bend the cable a bit if the amp is sitting on the shelf, but it does work. The NACA5 is stiff enough to remain in shape after bending.
Arthur
Posted on: 04 June 2002 by Rico
use a hair-dryer or heatgun to assist in bending the cable, if necessary. Hold the cable in the desired position (don't burn your fingers - they'll act like a heatsink at this point), wait while it cools in position. Blow gently if you feel like it (helps pass the time).
Rico - SM/Mullet Audio
