Another thread on racks.
Posted by: silklee on 20 November 2002
My setup
P25/CD5/92R/90/ES14.
I am thinking of getting the quadraspire Q4.
How does it compare to the Target? (I know they arent in the same price range)
__________________________________________
I was almost about to post it when i did a search and !! came upon this.
http://forums.naim-audio.com/eve/forums?q=Y&a=tpc&s=67019385&f=48019385&m=1941968945&p=1
unfortunately i only lasted 7 pages. I am looking for a decent rack at a decent price. Both mana and Fraim is way too expensive for me. If I could have afforded them, I would have gotten a 82 or 52 and a 250 instead.
Anyway, I don’t have much choices back where I am.
Target as we know has closed down and I could only find a 4 tier rack which is one tier short of what I need. Ideally, I need a tier each for the P25, CD5, 92R, 90 and accessories (ie my GSP phono and its power supply) so the target is one tier short.
I can order a 5 tier quadrashire rack from UK and have it shipped over. I read that the Rega TTs need a table that is light but rigid. Does quadraspire qualify in that aspect? And is the quadraspire Q4 the same as the QS ref that I see being mentioned? I can’t find any info of the QS ref from their website.
And does the column diameter matter? Which should I choose, 19mm or 32 mm?
http://www.quadraspire.co.uk/index_main.htm
What other options do I have?
