Would the real Yes Al*** please stand up.
Posted by: garyi on 27 February 2003
I have just listed The Yes Album on Ebay. I was under the impression mine was an original, and listed it as such but I could be wrong.
Its a single gatefold sleeve, shiney on the front dull on the back and the record centre is a single plum coulour with the atlantic badge.
However there are a number of listings saying the double gatefold is the original, with the three split colour centre.
Did I do wrong?
Posted on: 27 February 2003 by David Stewart
Gary,
Whoops! - you may have made a boo-boo there. The original 1st pressing of 'The Yes Album' should be in a gatefold sleeve with Atlantic Cat. No. 2400 101. The label is a distinctive two-colours one with a half-inch wide horizontal white band across the middle, red above it and plum colour below. What you have would appear to be a later re-issue. Hope this helps,
Posted on: 28 February 2003 by Peter Stockwell
Gary,
Yours looks more like an american pressing, not the polydor UK pressed UK. It's the polydor pressed Cat. No. 2400 101 which is considered the original.
They sell for £20-£35 depending on condition.
About 1974 Atlantic (and Warners and Electra, etc) passed into the Kinney group for UK editions with Knnnnn catalogue numbers.
It's possible to find some Yes LPs with K numbers on the sleeve (a sticker sometimes) but with the 7 digit plum label polydor pressing inside. My 'Fragile' is like that.
Peter
Posted on: 28 February 2003 by oldie
christ where have I been all these years.how do you find out the so called value of records i have original Yes, FLOYD,bARCLAY JAMES HARVEST,
LITTLE FEAT,LYNYRD SKYNYRD ETC SOME DISC'S GOING BACK TO 1958 PARHAPS i can afford those new 500 series amp's after all
Posted on: 28 February 2003 by Timbo
Dear Oldie - do you have a copy of Time Honoured Ghosts by BJH, mine was destroyed in an accident and I haven't been able to find another, even to record.
Tim
Posted on: 28 February 2003 by Mekon
Posted on: 28 February 2003 by David Stewart
You buy one of these
Rare Record Price Guide - but don't believe everything it tells you, you probably won't get anything like the quoted prices, unless it's absolutely
mint.
Try
Vinyl Records UK in Portsmouth, they appear to have a copy for £15.
Hi timbo yes Ihave that bjh time honered ghosts
If you can't get hold of a copy by other means
Icould crank up my old tape deck for you, as Im new to this game I'm not sure how you would get in touch though, as Iv'e noticed that people don't seem to splash their e.mail address's around I will be away tomorrow but back on Sunday .So If your stuck give me a blast or let me know how to get in touch.
all the best "oldie"
