Help how do you edit the login details
Posted by: Gary S. on 03 October 2006
When I first registered on the groupee community thingy, Windows asked me if I wanted it to remember my user name and password - I clicked yes, but I had spelt the email address wrong and now I have to edit it evry time I log on - does anyone know it I can change this?
Gary
Posted on: 03 October 2006 by Beano
It'll be in Internet Explorer Options, Tools, Content, Auto-Complete Forms, clear the checkbox out or delete history, something like that I would imagine.
There'll be some guru willing, able to assist more throughly along soon no doubt.
Beano
Posted on: 03 October 2006 by Gary S.
Beano
Thanks!! I've been editing that for the past nine months and was beginning to get a bit pi**ed off with it.
Really simple when you know how!
Gary
Posted on: 03 October 2006 by SteveGa
I think it is held as a cookie - delete you cookies as well.
If it is held in password manager type your correct username/password and say yes when it asks you to save it. You should then get the right option and the wrong option in a list. As far as I am aware actually editing the username/password requires regedit. Don't go there unless you know what youa re doing.
Another option use Mozzila instead if IE.
Steve
Thanks Steve, but I'm sorted mate - what Beano suggested did the trick. I knew it had to be something simple, I just didn't know where to look.
Gary
