Uniti and Apple - a 'iUniti' check!
Posted by: NewMike on 13 August 2010
Can't quite believe I'm posting this but...
Uniti well liked for the one box neatness and radio etc (I fancy a SX or Supernait). Household is Mac based and I have lossess ripped music on my big Mac that streams via Logitect Duet.
Read through the posts here and I want to check that the Naim will play nicely with the Mac. If I'm right I can add a bit of software so the Uniti copes with the format on the Mac. I assume you can pick the tracks etc either via iTunes or some application on an iPad or iPhone (Must stop buying Mac stuff!).
In together words are there issues I should know about? Asked a dealer but he said he was a PC man and thought Nains were too!
Posted on: 13 August 2010 by ferenc
you can use Elgato software as UPnP server on a Mac, and connect to it from the Uniti. For audio streaming it is free of charge. Convert Apple Lossless to wav real-time to make those files playable.
Posted on: 14 August 2010 by Jon Myles
Mike
Elgato works fine with the Uniti. And coverts Apple lossless on the fly to WAV.
However, I have to warn if your Mac is on a wireless connection and the Uniti is also taking a wireless connection from the router there can be drop-outs. With me it's been hit and miss.
I think Naim themselves advise two wireless connections are not ideal - but don't take that as fact because it's from memory!
Posted on: 14 August 2010 by vandergraafuk
Hi I have a Uniti and MBPro which Has my itunes on I use EyeConnect as the server and the Uniti renders the stream very well indeed. I can control it using the Uniti menu or I use the plug player app on my iphone all works seamlessly. This is on a wireless network and i have not had any drop outs while playing music, surfing and downloading. One word of advice is that not all routers are made equal and I think some of the cheaper models are particularly prone/troublesome to drop out. I use an Apple Time-Capsule integrated router in my network using the 5Ghz instead of the 2.4Ghz transmission. All my CD rips are in AIFF format which the uniti will happily play.
Posted on: 17 August 2010 by NewMike
Thanks for the info.
I've not heard the Uniti but preferred the SX sound to the 5i and don't really need a CD anymore. Should check out a Qute - interesting the chat on here about adding a poweramp to the Uniti...
