Apogee speakers and Naim amps
Posted by: Constantin on 23 April 2003
Did anyone tried to match the ribbons (i.e.Apogee Stage) with Naim amplification? It will work?
Or the better would be to match some hybrid ribbon speakers (Neat, Red Rose, etc.), in order to get the benefit of utmost transparency in the mid upper registry
What do you suggest? Right now I have Linn Kan mkV speakers and try to up-grade at this level.
Constantin
Posted on: 23 April 2003 by Frank Abela
Constantin,
Everything I've read about Apogees is that they dip to around 1 ohm impedance. I think a Naim amp will have problems with this!
Frank.
All opinions are my own and do not reflect the opinion of any organisations I work for, except where this is stated explicitly.
Posted on: 23 April 2003 by bjorne
Is Stage a later, smaller model? If so they are somewhat easier to drive than the earlier models with an impedance around 4 ohm. If they are an older, big model I believe you will need a bigger amp.
Posted on: 23 April 2003 by Constantin
Thanks guys,
Bjorne I think they have 2 ohms impedance, 1995 model.
Anyway what other possibilities would be to get the same /most closest result?
Constantin
Posted on: 24 April 2003 by Rob Doorack
Apogee speakers developed a reputation - fairly or not - as amp - killers. Here in the US they seemed to be most frequently paired with very powerful Krell and Levinson amps that could double as arc welders. One factor to consider is that Apogee is out of business although there is a lively user group and some commercial support. Take a look at the
Apogee Users website and
the Ribbon Speakers site for more information on parts and support.
If you're sold on the sound of panel speakers you might consider
Quad electrostatics. A couple of friends with reliable judgement in such matters think the new Quad electrostatics are among the best speakers ever, even when judged by flat - earth standards.
