Out of space error on Sky+ box
Posted by: BigH47 on 21 April 2007
Any one had an out of recording space even though the box is saying there is 80% or more available?
Howard
Posted on: 22 April 2007 by JamieWednesday
Yeah, is lousy bit of kit. I'm on my 5th.
Do the usual powering off and on again but it was a hard drive error on mine.
Posted on: 22 April 2007 by NeilM
The other option is to a Sky+ planner rebuild.
Press Services, 4 0 1 Select then choose option 7 on the installer setup menu
Give it a go and see if it helps
Neil
Posted on: 22 April 2007 by BigH47
Thanks Neil I have done that but of course you don't know if it's fixed until it fails again.
Howard
Posted on: 22 April 2007 by SteveGa
Also have a look here. They found a possible cause was disk management set to AUTO.
Steve
