burning cd's on a macbook pro
Posted by: scottyhammer on 03 December 2009
Is there a simpler/ quicker way to burn cd's (by that i mean an album) not sigle tracks from various albums to make a mixed playlist.....other than what ive described in making a playlist. I find it frustrating having to drag n drop songs into a playlist first just to burn an album for the car.
Thanks, Scotty
Posted on: 03 December 2009 by Chief Chirpa
Hi Scotty,
Assuming you're using iTunes...
Type the album name in the search box top right and you should be left with just those tracks; then Edit > Select all > File > New Playlist from Selection.
Works for me.
Posted on: 03 December 2009 by scottyhammer
Thanks for the fast reply Chief. Winker
