entry level naim pre power combi
Posted by: silklee on 09 June 2002
Hi guys,
what is the entry level pre power combi for naim? or would i be simply better off getting the nait?
kinda of confused about all the naim models around.
Posted on: 09 June 2002 by herm
Hi SL
the current entry level pre power combo is 112 / 150. It's the decoupled Nait 5, as it were. Slim, with the little itty bitty round buttons and the arch logo.
You can check members' experiences with the 112 / 150 (usually quite good) by using the search box in the right hand corner down on the opening screen of the Hifi Corner
Herman
