Robert Silverman Plays Beethoven
Posted by: Todd A on 14 March 2006
First some facts. This cycle, on Orpheum Masters, was not recorded in a normal fashion. That is, this set is not a compilation of concert performances or multiple studio sessions. Rather, the cycle was recorded using a Bösendorfer 290SE reproducing piano to playback recordings previously prepared by the pianist. This piano is basically just a standard Bösendorfer grand with an elaborate and accurate computer control system added. And it apparently isn’t cheap. At the time the recordings were made, only 32 of them existed, and two of them were owned by the benefactor of this recording, one Aaron Mendelsohn, in whose home the whole process took place. Silverman recorded and prepared the sonatas during 1999 and then over one weekend the set was committed to tape.
This cycle was engineered by John Atkinson, the Editor-In-Chief of Stereophile, so sound quality is in the forefront this time around. I wanted to see, or rather hear if his idea of good sound matches mine. But I had to make some allowances. First of all, the concert grand was confined to a two-story, 20' by 50' room in Mr Mendelsohn’s home, not exactly the ideal size venue for such a large piano. But that didn’t seem to matter. In stark contrast to the closely recorded cycles by Georges Pludermacher and (especially) Craig Sheppard, this set actually allows one to hear the surrounding space. Truth to tell, it’s actually a little more spacious than I usually prefer, but the quality of the sound is superb. Mr Atkinson’s credo here seems to be truth in reporting. This sounds very much like a big piano being played in a relatively small space. The sound is tonally and timbrally accurate, and never hard. Of course, this is a recording of a Bösendorfer, so the sound is different from a Steinway. The lower registers are weighty and bold, and the upper registers are tangy ‘n’ tart, bright (but not Fazioli bright) and somewhat bell-like. Even though the microphones were close to the piano, the sense of space one hears means that one does not always experience aural X-ray clarity; sometimes in louder passages the sound becomes blended, just like in recital. Again, truth in reporting. Mr Atkinson most definitely would not be a good engineer for an American Idol reject to use, much to his delight, I’m sure. More information is available at the Stereophile website for those who are interested.
To the pianist himself. Like both Pludermacher and Sheppard, Robert Silverman has been around the block a few times. He’s been ensconced in a teaching role at the University of British Columbia for over thirty years. He’s made a number of recordings for small labels covering mostly standard repertoire (Brahms, Liszt, and Rachmaninov, for instance), as well as other recordings on the Stereophile label, including a forthcoming set of the Diabelli Variations, which I’m fairly confident I’ll buy. He’s done the concert and recital circuit for years and has collaborated with a number of notable artists, and received various awards. So he’s got the experience and a serious background.
But what about the music? Well, from the first notes it was clear that this set is something wonderful. The opening Allegro sounds fresh and clean, with wonderful and subtle dynamic variations – more so than most recordings I’ve heard – and a natural overall feel. By that I mean that the music just unfolds before one’s ears. Silverman doesn’t rush, he doesn’t make it a point to underscore everything. He just plays. Throw in a rich lower register that is both clear and occasionally prominent with Silverman’s penchant for providing a flowing, rhythmically solid underpinning that doesn’t sound forced, and, well, one just sits and enjoys the music. The Adagio shows more of what is to come. It sounds touching and unforced. There’s some emotion in the playing, but not too much. Same with the Menuetto, which also benefits greatly from essentially perfect tempo choices, perfect use of pauses, and a flowing, comfortable feel. The piece ends with a Prestissimo that again displays expertly judged tempi and an emotionally satisfying approach. The playing is intense and cutting at times, and sounds superb. It’s been a while since I so enjoyed the first sonata.
Much the same can be written about the second sonata. Silverman opens the Allegro vivace in crisp, clean fashion. The first return of the opening material is even faster and noticeably louder, with superb dynamic gradations clearly evident. The next return of the material is softer and warmer. The runs and scales sound superb; they’re clear and well done, but not an example of ice-cold perfection (which has its place!). Then Silverman throws some passion into the mix. His playing is definitely on the romantic side. The Largo is superbly played from start to finish. Snappy bass is married to searching right hand playing. I confess to just sitting and taking it in without much concern for every little detail. The Scherzo opens with quickly dispatched figures and has a rich, darker middle section. The whole thing is richer and more varied than is often the case. The Rondo offers more of the same, though some of the playing almost sounds (but never quite becomes) stiff, but not in an unpleasant way. The middle section is rough and boisterous – right on!
The third sonata makes it three for three. The Allegro con brio is fast and sharp to open (the latter trait due to the Bösendorfer’s upper registers), with unique and exciting accents. The hefty lower register adds to the playing, and the whole thing just grooves, man. Silverman puts on a non-virtuosic virtuosic display; he plays everything well but doesn’t overdo anything. The Adagio sounds more tonally graceful, and Silverman again utilizes pauses in a most satisfying manner. The Bösendorfer’s quick decay helps render the music simply and directly effective, and when Silverman ratchets up the tension, the sharp upper registers just help things along. The Scherzo sounds vigorous and beefy, with softer interludes offering nice contrasts. Throw in a suitably tumultuous middle section, and how can one resist? Silverman ends the work with a light, almost soaring Allegro assai that veers into an almost songful style at times. It’s fun and weighty and groovy, but never rushed but also never sluggish. Why, it’s just right!
Comfortable. That’s how the opening Allegro molto e con brio of the fourth sonata sounds. Silverman takes the movement at a comfortable pace – which is not the same thing as a sluggish pace – and adds flavor by throwing in some piquant notes and chords and some hefty, venue-filling crescendos. The playing flows and sounds laid back, but not in a mushy way; it’s comfy and rugged. Nifty. The Largo is slow, as it should be, and Silverman proves adept at utilizing pauses for dramatic effect. More of that Bösendorfer weight combined with some tersely punched out three note figures make the whole thing quite fine. The overall sound is a bit less overtly romantic than some of the previous playing, and the tension does weaken at times, but not enough to harm the piece. The Allegro opens smoothly and richly, and somewhat leisurely, before soaring in a pleasant way. The middle section sounds appropriately darker, with prominent bass. To close, Silverman plays the Rondo with a slightly laid back demeanor and more or less cruises along to the end. Yes, there are brief interruptions where things get a little tougher, but the whole thing just moves along comfortably. Silverman’s four for four.
Moving on to the second trio finds Silverman in even better form. The Allegro molto e con brio opens the first sonata with a powerful opening chord and well-paced (not too fast, not too slow) rising arpeggios with a fluid transition to the subsequent, lyrically played material. The Adagio molto sounds lyrical and beautiful. The rising flourishes sound captivating – they’re soft and delicately nuanced, but never weak or soggy. The at times spiky left hand playing just helps matters. It’s big, warm, and ingratiating, too. To close, Silverman plays the Prestissimo in an initially restrained manner just to pick things up and to deliver huge crescendos. The distant, unfettered recording really lets the dynamic swings shine. Throughout the movement, Silverman resorts to an almost Pludermacher-like deployment of pianistic tricks. He’ll hold a chord just that little bit longer, tweak a note here, and cut short another there. It all sounds natural and unforced and never obtrusive. Another winner.
The second sonata of the bunch extends the streak. Again, Silverman opens with an Allegro taken at a comfortable pace, and plays with a sense of fun and lyricism that makes the end sneak up on the listener. One doesn’t want it to end. The Allegretto sounds rich, dark, and slightly urgent to open, and has a sharply played, strong ending. The Presto opens at a nice clip, just to pick up a bit more. Silverman never sounds hurried, though; instead, he lets the good times roll with some endearing bass weight and articulation. Bless his heart, he includes the repeat, and ends the work on a strong note.
So far Silverman has nailed every sonata. Nary a dog is to be heard. But his best sonata to this point comes in an amazing reading of Op 10/3. The Presto opens slightly slower than I usually prefer, only to speed up handily while Silverman also deploys his rubato in a most captivating fashion. The development section is smooth ‘n’ groovy, and things just seem to get better right through to the end. Subtle variations in almost all aspects of the playing really spice things up. It is the Largo, though, that separates this recording from so many others. A number of pianists make this movement sound like a precursor to the great Adagio of the Hammerklavier, but Silverman does one better. He makes it sound like a brother to the great movement. The movement opens in a dark fashion, with sadness practically oozing out via cutting treble tears. The anguished, angry outbursts that follow sound emotionally painful. Silverman makes the piece weep, complete with pauses that sound like the musical equivalent of gasps for breath. The effect is mesmerizing and moving, and draining. The Menuetto thus sounds like an upbeat tonic to make one get over the trial of the second movement. That lower register goodness so prevalent in recordings of Bösendorfers remains, and the sound is nicely blended. Even sunnier is the Rondo, which brings the sonata to a cheery conclusion. This is a remarkable recording.
A few hours prior to listening to Silverman’s take on the Pathetique, I revisited Ivan Moravec’s recording, which has been one of my favorites for a few years now. Silverman is at least as good. Maybe even better. His take is most certainly different. The Grave opens with drawn out chords and then transitions to faster playing with nice flourishes and beefy bass playing. There’s a nice, long pause before the Allegro, which ends up being slightly slower than I usually prefer, but is still successful. Silverman again deploys his rubato in a satisfying manner, and he makes the intensity of the music undulate between softer playing and loud, swelling crescendos. The Adagio cantabile is rich, grand, touching, and moodily songful. The middle section is predictably more intense, and just as moving. The concluding Rondo is less intense and moody than the opening two movements, but its romantic overall feel and huge dynamic range really hit the spot. Outstanding.
After hearing so many different takes on the Op 14 sonatas, I was starting to think that the first sonata just isn’t as good as the second. Silverman to the rescue! The opening Allegro is open, free, and downright fun. Silverman never rushes anything, but he never sounds too slow. He just lets the music unfold. The middle section is more serious, as it should be, but it’s still lyrical. After that, Silverman dispatches the scales nonchalantly and brings the movement to a charming close. The Allegretto is taken at a slow-ish pace and sounds bittersweet but not overburdened by “deep” playing. The concluding Rondo is quick and jovial, with pretty much everything done just right. Silverman reaffirms my faith in the piece’s quality.
The second sonata is also very good. The Allegro opens in a lovely, laid back, and warm ‘n’ cheery manner, and floats along thusly, interrupted only by a beefy middle section and fine, quick runs. The Andante opens in a slow, deliberate fashion and almost sounds clumsy, though purposely clumsy. Silverman picks up the pace so that he can end with a distinct, loud final chord. To close, he plays the Scherzo in a light, punchy way to open only to decrease the volume precipitously while still playing fast. A neat trick. The final third of the movement is played mostly straight and ends strongly.
The final sonata of the opening batch witness a slight diminution in overall quality. Silverman opens the Op 22 sonata with an Allegro con brio that cruises along at a brisk but not driven clip. There’s some nice left hand accenting and some powerful, swelling playing where needed, and a few times he holds a note a little longer than one expects, rather like a singer ending a phrase with a sustained note thrown in for flavor. The Adagio is softer, quite lovely, and characterized by a fine overall tempo. The playing is somewhat dispassionate to start, though the terse middle section and lyrical ending add a bit of emotion to the playing. The Menuetto is clear and direct, and the concluding Rondo opens in a soft, singing manner and then proceeds to end the piece in a leisurely manner, with only the beefy middle section to offer contrast. This is a good reading, but it doesn’t quite match up to what came before it. No matter, I like it.
I’ve known about this cycle since it first came out, but I didn’t get around to hearing it until now. That was a mistake. There is a whole lot to savor in this set. Everything sounds right. Silverman’s playing is all about the music. He’s not out to show how loud he can play, or how fast, or how he can twist the music into virtuosic slop. Rather, he chooses to use his technical ability to let the music speak for itself. His playing does have personality, that’s for sure, but this is more about Beethoven than Silverman. Of the three cycles I’m working through right now, I have no doubt that this is my favorite and the one I’ll turn to most often, at least in the opening eleven sonatas. (I’ll be surprised if the same doesn’t hold true for the remaining 21 sonatas.) The Bösendorfer takes some getting used to – perhaps twenty to thirty seconds or so – but after that, it’s smooth sailing.
Posted on: 16 March 2006 by Oldnslow
I really enjoy reading your takes on these great sonatas by various pianists. This one sounds like the most unusual, given the way the recordings were made. Wild!
Any consideration of surveying varous pianists playing Beethoven's other great piano masterpiece, the Diabelli Variations? I'd like to hear your thoughts on various interpretations. Also, I would really enjoy a survey on Kempff's 50s sonata cycle.
Posted on: 16 March 2006 by Earwicker
Brendel's digital recording is by far the best, but he doesn't seem very popular round these parts...! Winker
EW
If you are referring to the live recording by Brendel, which I think was issued as part of the EMI great pianists of the century series, yes I have that and will get it out for another listen. Recent recordings I like are by Andreszeski (sp?!!) and I recently picked up a reissue of Benjamin Frith's recording , which I believe was originally issued on ASV--very nice indeed. I love this piece, and prefer it to the Goldbergs.....
Posted on: 16 March 2006 by Todd A
Possibly. Without even trying, I've got 10-12 versions already, and will probably have a few more before the end of the year.
Back to Silverman: I will do a more detailed write-up in the next few days, but the second batch of sonatas (through Op 49) is, if anything, even better than the first.
Posted on: 17 March 2006 by Earwicker
I meant this studio one - I've yet to hear better:
I heard Brendel's pupil, Paul Lewis, play it live a few years ago, and I suspect there's going to be a pretty special recording of the piece by him too in due course!
EW
Posted on: 17 March 2006 by Cosmoliu
Nice write up, Todd. I have owned the Silverman set for a couple of years now and I agree: I keep coming back to it. Part of it is the superb recorded sound, but I also like Mr Silverman's playing very much.
Norman
Posted on: 17 March 2006 by Todd A
If Lewis' recording of the Op 31 sonatas is any indication of what is to come, I don't hold out the same high hopes you do.
Posted on: 18 March 2006 by Earwicker
I haven't heard it, but it's been very well reviewed. Have you heard his recording of the Liszt Sonata plus misc late pieces? That's by far his best and most representative recording to date that I've heard.
All modern recordings of the Op 31 sonatas have Brendel's last digital enregistrement to contend with - a recording that must surely make other pianists wonder why they should bother!
EW
Posted on: 20 March 2006 by Todd A
I got back underway expecting good things from the Op 26 sonata. Don’t know why, specifically, though Silverman’s direct, unforced style seemed to portend good things. I was right. But in ways different than I expected. Silverman opens the piece with a poised, very formal Andante. Sure, it sounds tonally appealing and rather beautiful, but its formality makes it sound earnest. Then each subsequent variation is played more or less the way they seem they should be played. The fast variations are fast and articulate, but never flashy, and the slow variations are slow and attractive and there to be savored. Silverman utilizes his by now familiar interpretive devices perfectly. He uses an appealing accent here, and truncated chord there, and whatever else seems right elsewhere as needed. The Scherzo offers more of the same, though here the primary emphases are on speed (though not too much) and large dynamic swings. The funeral march – the heart of the work – is splendid. Silverman again plays in a formal manner, with his serious approach adding gravitas to a movement requiring it. His playing certainly sounds funereal and crisply march-like, with powerful, cutting crescendos adding angst when and where appropriate, and the middle section is notably powerful. The work winds down with Silverman playing the Allegro quickly and articulately with a nicely intense middle section flanked by comfortably dispatched outer sections. A superb recording, and one that compares favorably to the best I’ve heard and certainly surpasses most.
As I’ve written before, the first of the two sonatas quasi una fantasia is one of my favorite LvB sonatas, and it has become increasingly important to me in assessing a pianist’s overall achievement in this music. Silverman’s achievement is notable. The piece opens with an Andante that is simultaneously relaxed in overall feel but taut in delivery. There’s a subdued anxiety there; something’s going to happen. And that something is the Allegro, which bursts into being with powerful bass coming out of nowhere. The return of the Andante is much like its first appearance, but more lovely since the Allegro is out of the way. Silverman plays the Allegro molto e vivace in a somewhat measured way, but he plays with huge dynamic swings and delivers a rollicking middle section. The Adagio con espressione sounds like a somewhat somber reprise of the Andante, appropriately enough, and as such is rich, moody, and beautiful. Silverman ends the work by opening the Allegro vivace quickly, with a rocking rhythm, and large dynamic swings and bite, and, most importantly, good old fashioned oomph! One just revels in the powerful build up and final, towering chord before the return of the Andante theme and the super fast, super strong end. Yowza! A corker.
Less important to me is the Mondschein. Too many players try to do too much with this piece, often turning it into a showboat piece. (“How fast can the Presto agitato be played?” often seems to be the question.) Blech. Silverman comes reasonably close to not interpreting the work at all; he just plays the music and lets Beethoven’s writing provide musical sustenance. The opening Adagio sounds serious and solemn, almost barren, and Silverman does an admirable job of riding the sustain pedal while still providing treble playing with a clear attack for each note. Silverman keeps the Allegretto serious and pretty much straight with only some brief pauses before the bass chords thrown in for variety. To end the piece, the Presto agitato is delivered in swift fashion, with rolling, powerful bass, and sharp treble. The energy and intensity levels are judged just right. The whole thing is just right.
Even righter is the Pastorale. Silverman opens the piece with an Allegro taken at a somewhat brisk tempo and plays with an insistent and solid left hand that remains prominent but not obtrusive throughout. Silverman spins out the melodies with his right hand and otherwise plays in a most tuneful manner, but he keeps things taut, too. The middle section is more biting and substantial, and then he plays through to the end with a most appealing tautness. The Andante opens with the tension of the prior movement mostly in tact, with the Bösendorfer’s bright upper registers adding a dash of urgency to this otherwise genial movement. The middle section is plucky fun – it sounds as though Silverman makes the piano laugh, almost as though he’s telling a somewhat naughty joke and chuckling while doing so. But then the opening music returns and comes to an end with a strong coda that seems to impart a sense of drama. The Scherzo comes off as nothing less than a vigorous, jaunty poke in the eye – or ear, I guess. The concluding Rondo brings the work to a wonderfully lyrical conclusion. Each movement sounds distinct, and Silverman plays superbly throughout, but what is ultimately most impressive about this reading is how the whole thing coheres; it just moves along flawlessly from start to finish. Superb.
Time for the critical three. Surely Silverman should do well here given how well he’s done up to this point. That’s certainly what I hoped. I was not disappointed with the first sonata. The Allegro vivace opens at a nice pace but in a somewhat soft manner. It’s good, but not especially unique or insightful. Then Silverman proceeds to play the piece in a fashion indicating that he reexamined the piece afresh and reveals insights into everything. Rubato abounds, myriad dynamic gradations tickle one’s ears; Silverman basically offers subtle, unique playing that makes everything sound new. He’ll play a bit slow for a while, then fast. He’ll play with a buttery-smooth legato then with a sharp, pointed staccato. He’ll alter the emphasis of a phrase, cut short a note, vary dynamics within an arpeggio. His touches are everywhere apparent. In that regard, he reminds me of Anton Kuerti in this work, and he’s just about as successful. This variable goodness extends to the Adagio grazioso. The first thing one notices is the trills – they’re different. Rather than just launch into them, he plays the first note, takes a (relatively) long pause, then proceeds to the rest of the trill, which he varies in terms of tone. All the while, Silverman plays with a nearly bel canto left hand that somehow manages to offer rock-steady rhythm. Sweet! The middle section is fast and strong and vivacious – it’s just superb. The return of the opening material finds Silverman playing more vigorously than before, but he never pushes anything to hard. The piece ends with a Rondo that’s at once leisurely and lyrical, and brings to mind an image of a good old boy sitting in his favorite chair, sippin’ some whisky, and strumming a guitar with disarming and unexpected technical acumen while impressing more with musical fun rather than showmanship. Translate to the piano (sans the whisky, I’m guessing), and you have one fine ending. It’s hard to point out any one or two or ten standout parts; it all blends perfectly.
I guess after four straight knockout or near knockout performances Silverman was bound to deliver something less impressive. That happens with the Tempest. The works opens with a slow, rich, somewhat plain Largo. The Allegro is suitably faster and more intense. One benefit of the more distant recording perspective is revealed by the dynamic contrasts in Silverman’s playing. The contrast is there, but it’s not exaggerated; it sounds unforced. Silverman uses the pauses well, heightening the drama, and then plays the long two-note figure in a clear, sharp way highlighting the contrast between it and the left hand tumult down below. The Adagio opens with a rich, hazy arpeggio before moving on to playing that is both lyrical and melancholy. The concluding Allegretto is played in a measured but flowing way, and sounds more tragic than the preceding movements, with at times cutting treble helping in this regard. Silverman also uses the Bösendorfer’s powerful bass to help accentuate the dynamic contrasts. Over time, the repeated theme takes on a desperate sound that works quite well. Overall, I do enjoy this recording quite a bit, it’s just that it’s not quite up to the level of the immediately preceding recordings.
The last of the trio finds Silverman playing at almost the same level as in the first of the batch. The Allegro opens in a somewhat leisurely fashion. Silverman seems to be smirking, if you will; the listener expects something more vigorous, something more boisterous. It’s not to be, at least not at the outset. As things progress, though, Silverman does become more animated. He relishes pounding out the boisterous bass notes when they come, and he impishly plays the long trills, then he reverts back to his sly, smirking style. His style is subdued and subversive. A novel and compelling approach, to be sure. Another nice touch comes at around 5’ when the playing takes on a somewhat annoyed, snarky feel. The Scherzo opens with a scampering left hand played in tight, controlled fashion – almost as though the pianist is hunkered down ready to pounce – with some nice right hand playing that just cruises along. Then Silverman pounces, pounding out the hilarious outburst, then he returns to the opening material again. The Menuetto, by contrast, opens beautifully – almost tenderly – and remains so with only the forceful middle section acting as a musical poke in the ear. The work concludes with a fast, flowing Presto con fuoco that benefits from a solid left hand underpinning. Another fine reading, and one sure to get repeated listens in these parts.
This batch of sonatas ends with the Op 49 works. The first one opens with a rich, substantive Andante tinged with resigned retrospection. Who’d a thought this movement could be so serious yet fun? (Well, others do manage it.) The Rondo is a sunny, vigorous good time. The second sonata opens with a solid yet fun Allegro and ends with a quick, emphatic, strong yet fun Tempo di Menuetto. Both works come off slightly better than normal.
The second batch of sonatas is, if anything, even better than the first. Silverman has yet to deliver a recording that I dislike. At his best he can withstand comparison to just about anyone, and at his less-than-best (because I can’t write “worst”) he’s excellent.
Posted on: 21 March 2006 by pe-zulu
Dear Todd
So this is a cycle you ( of course I ) must have. But is it available in Europe?
Posted on: 21 March 2006 by Todd A
Yes, and not in retail outlets. I believe the only place to readily buy the set is from the Stereophile website.
Posted on: 22 March 2006 by Oldnslow
EW--could you give me a recording date for that CD of the Brendel Diabelli Variations? It may indeed be the one in the EMI Great Pianists of the Century series, and it isn't a live recording on that set (I was confusing it with the performance of the Hammerklavier). Thanks
Posted on: 24 March 2006 by Oldnslow
EW--the Brendel Diabelli I have was recorded 2/76 in the UK--is that the performance you refer to?
Posted on: 24 March 2006 by Earwicker
No, it's the digital one, recorded in 1990; it's awesome.
EW
Posted on: 28 March 2006 by Todd A
After twenty recordings ranging from good to great my hopes were high. The third batch of sonatas has some biggies. Silverman more than meets any expectations, starting with the Waldstein. Brisk and firm to start, Silverman makes the piece sound big from the start. The first slow down in the playing takes on a wistful feeling, and then when he speeds up again Silverman plays even quicker than before, and he expands the scale of the music, too. The return of the opening material is quite something. The overall tempo, dictated by the left hand, is not especially fast. Indeed, it’s slow-ish, but Silverman spins off notes swiftly and precisely with his right hand. It’s got that clear part playing thing going on. Silverman’s cycle is hardly a virtuoso fan’s delight, but here he shows that he can play with dazzling precision when needed. Here it’s needed. Anyhoo, the Introduzione is spot-on; it’s pensive, it’s restrained, it’s uneasy, it’s almost angry at times. It’s just right. So far, so good. Then comes the Rondo. It opens in a nearly dream-like fashion, quiet and subdued and a bit ambling, but then it climbs to near ecstatic heights than expands into a large-scale feast for the ears. The long transitional trill starts off small then gradually speeds up, becomes bigger and more powerful, and then Silverman throws the weight of the Bösendorfer behind it and plays loudly yet in controlled fashion. He alternates the dreamy and grand playing to perfect effect through to the end, and makes the piece sound grand and massive and purely enjoyable. Hot damn.
The little Op 54 sonata can sometimes (and maybe often) be something of a let down after the Waldstein, especially one as well done as Silverman’s. Not this time. Silverman opens the In tempo d’un Minuetto in a somewhat restrained yet almost literally danceable fashion. His beat is relaxed, his playing incisive, the effect charming. Until he launches into the meatier second section, which sounds cutting and most decidedly vigorous. Small, nothing! The opening minuet returns in more gilded fashion just like it’s supposed to, and then the powerful second section returns for a brief, pointed, invigorating run through before the final appearance of the minuet transmogrifies into a trill laden exercise in musical ornamentation. Spiffy. How to follow such a strong opening movement? With an equally strong closing movement! Silverman plays the Allegretto in perpetual motion fashion; that is, he just lets the notes flow in a most natural and unforced (though occasionally forceful) manner. It’s lyrical, it’s jaunty, it’s just plain fun to listen to. Hot Damn!
Then comes the Appassionata. Somewhat quiet and tense to open, the piece explodes into an intense, passionate outpouring of emotion translated to the ivories. Silverman delivers all with superb control, room pressurizing weight, and fine clarity (given the realties of the instrument and recording style). Then things slow down, and Silverman opts to elongate certain phrases just a smidgeon for effect. All the better to offer maximum and satisfying contrast for the powerful, throbbing playing that follows. It is in this piece that one really begins to appreciate how much more dynamic a slightly more distant sounding recording can sound. Silverman’s range is huge, yet small dynamic gradations are easily (and greedily!) heard. The peaks-and-valleys approach works both sonically and musically. The Andante con molto offers a needed rest, especially for the listener, and Silverman again delivers. This ain’t no mushy middle movement though. The playing is calmer than in the opener, but it’s firm, too. The overall tempo is perfectly judged, and that means that everything unfolds in a most satisfying manner. Then Silverman speeds up dramatically at the end and launches into the concluding Allegro ma non troppo with a sharp, piercing chord and a rumbling lower register. Things ease up a bit but remain notably tense until about 1’32” or so when Silverman just unloads. This goes on for twenty or so seconds, then Silverman regroups for a brief while, then unloads again. The movement alternates thusly until the end, when Silverman pounds out a thunderous coda to this top-notch recording. Hot Damn!
After three amazing recordings in a row, one might be tempted to think the Op 78 and 79 sonatas might get short shrift. That ain’t the case – not even close. Silverman opens the Op 78 sonata in a rich, dark hued, almost haunting fashion. It’s more substantial than one might expect. The piece transitions to a perfectly paced Allegro ma non troppo, which, while not as heavy as the opening, maintains a sense of urgency married to sadness until it gives way to a more upbeat tone. This is one meaty (yet brief!) musical journey. But that’s not all! The Allegro vivace closer is vigorous ‘n’ vivacious and ends the piece in sunnier fashion, and with a nifty flourish. The Op 79 is more substantial than normal, too. Silverman opens with a Presto all tedesca that is swift, firm, but unabashedly fun. Beethoven liked the little two-note joke he wrote in the opening piece, and Silverman seems to, too. He loves to tell it, retell it, refashion it a bit, and then retell it yet again. Is it Beethoven or Silverman I write about? Hard to tell, really. The “off key” ending is fun and caps off a fine starting movement. In the Andante, Silverman maintains a gently rocking left hand throughout to offer support to a lamenting, crying right hand. It definitely occupies a world closer to the late sonatas than is often the case. Silverman ends the piece with a sunny and bright Vivace, as one might expect. That’s five for five in this batch so far.
The streak ends at five. That’s not to say the Les Adieux is poorly done – it’s actually pretty good – just that Silverman doesn’t play it at the same level as the preceding works. If anything, that just serves to underscore how good the preceding recordings are. Silverman opens with a slow, sad, almost processional Adagio before playing the Allegro in a small-scale, light manner. There’s little heft; the piece takes on an intimate feel. The protagonist is bidding a fond farewell to a close friend in a non-ceremonial fashion. It reminds me of Paul Badura-Skoda’s take in some ways. The Adagio cantabile sounds like nothing other than a personal lament at the friend’s absence. It’s not especially intense, though there is a slightly stinging feel to it at times. It is in the concluding Vivacissimente that Silverman finally expands the scope of the piece to quasi-orchestral dimensions, and it is here where he delivers a striking and ebullient feeling. Overall, this is very good, but there are a number of others I prefer to this one. I do believe I’ll be listening to this one again, though.
Silverman just keeps getting better. If the remaining six sonatas are of the same overall quality of the six just covered, I’ll be happy indeed.
Posted on: 31 March 2006 by Todd A
Up to this point Silverman’s cycle has been pretty much all I could ask for. He hasn’t bombed even once, and his best interpretations compare to anyone’s. So I approached the last six sonatas quite enthusiastically. So enthusiastically that I thought I should try to hear even more of Silverman’s Beethoven. As luck would have it, my local CD hut still had a copy of Silverman’s 1990 Rouvain Recordings disc of the last three sonatas. I dutifully snapped it up. Somewhat like the Orpheum cycle, these recordings were made on a special piano, though here it is a truly unique piano. Silverman played on Steinway #500,000. To commemorate the special piano, the Steinway Company had a custom sculpted case made and then had it emblazoned with the signatures of hundreds of Steinway artists, Mr Silverman included. Sonically it sounds like a Steinway. The only other item of note is that the recordings of all three sonatas were made in one day, so only a limited number of takes could be used. Anyway, these recordings will be covered in due time. For now, it’s time for the Op 90 sonata . . .
It’s predictably good, but it also extends the streak of only very good recordings to two. (How I wanted a great one.) There’s nothing really wrong with it, it’s just that it doesn’t sound as relatively good as what Silverman achieves elsewhere. In the opening movement, Silverman mixes the Bösendorfer sound and some tightly dispatched chords to create a sense of urgency during the bolder, louder sections, and elsewhere he plays with notable speed and a pointed ‘n’ groovy style. The second movement is characterized by some careful, deliberate, slow playing that veers dangerously close to syrupy lyricism. It’s beautiful and calming, and the whole sonata sounds nice enough, but it doesn’t scale the heights.
Imagine my dismay when the op 101 extends the streak of only very good recordings to three. What’s going on here? (Okay, I wasn’t really dismayed; I just wanted more. Again.) The Allegretto, ma non troppo is on the slow, relaxed side, with Silverman not really pushing anything (except for a brief passage centered around 3’35”) and achieving a serene, almost transportive quality. The Vivace alla marcia is strongly characterized and delivered with a wry smile (or so it seems). This is serious, late Beethoven – but not too serious, a darker, world-weary middle section aside. The Adagio sounds slow, somber, and decidedly introspective. You’re hearing someone working things out musically in terms you can never fully understand – after all, it’s not you. It sure is good to hear, though. A wonderful trill leads into an Allegro that is sharp, pointed, and fast, but that soon gives way to a beautiful reappearance of the opening material. It is here where the music slowly but perceptibly morphs into that meditative, transportive late LvB that I so enjoy, and it takes on a jubilant overall sound. The fugue is taken at a somewhat measured pace, but still sounds quite nice. Overall, there is a lot to enjoy here – but I just wanted more.
And now it’s time for the Hammerklavier. Can you believe this recording makes four only very good recordings in a row? What gives? The work opens with an Allegro taken at a broad tempo – all the better to make the work sound large scale. Silverman’s grand conception results in less forward drive than in some other versions, but the trade-off is that there is architectural cohesion. Everything has its place and is put in said place just right. All of Silverman’s previously mentioned traits are there, and he throws in some nice individual touches (as in the opening pages when he will let a chord decay just that itty bitty bit longer than one expects), but they and a romantic overall feeling are all less important that the overall arc of the piece. The Scherzo is more along the lines of what one might expect. Silverman again adopts a somewhat broad overall tempo, but the dynamic range and rolling bass and undulating sound all sound pretty nifty. The great Adagio comes off quite well, but doesn’t quite compare to the very best out there. It opens with a desolate sound, but Silverman’s playing quickly assumes a sense of subdued, resigned desperation. He’s more engaged than at the open, but for what? It’s tragic but not hysterical. The protagonist has accepted his fate. But then, roughly mid-way through, there is an outpouring of anguish. It’s not fevered or exaggerated, but it’s there. The subsequent music is less tragic and less obviously emotive, but it is moving in a way words cannot adequately describe. To end the work, Silverman opts to play the Largo in a slow, slightly ambling way, as though waiting for the grand fugue. And grand it is. Silverman plays with speed and vigor not present in the rest of the sonata, with superb part playing, and notable strength. No, the playing does not achieve aural x-ray clarity (in distinct contrast to Craig Sheppard) – because of a combination of the instrument, the playing style, and the recording – but what is there is clear enough and certainly gets the message across. This is a very fine, big-boned, long-breathed performance, that is certain.
Silverman gets his groove back with the Op 109 sonata. By that I mean he plays at the highest level and delivers a recording that can be compared to anyone’s. I decided to listen to the Orpheum recording first, just because. The Vivace, ma non troppo opens in reasonably brisk fashion but sounds supremely smooth, then slows up a bit so that some strong, sharp forte chords can receive appropriate attention, and the transitions back to quick ‘n’ smooth. The contrasting themes and their delivery very quickly create that transportive, meditative quality that is so essential in these works. As things progress, Silverman throws in some delicate, almost precious playing, but it sounds sublime. The whole thing does. It’s a world in 4’12”. The Prestissimo is not especially thundering or fast, but it sounds ominous and unsettling. In stark contrast is the Andante, which sounds gorgeous and revives the transportive quality of the opener. Silverman plays with a broad tempo, but it doesn’t sound slow. It sounds timeless. Then come the variations, and Silverman improves on his earlier playing. The first variation is more beautiful than the theme, the second spiky and pointed but measured, and the third fast and strong and dynamically variable. The final variations return to a more ethereal sound world, the last one sounding transcendental, if you will. And finally, the restated theme beguiles with its beauty. Everything is played just right, and in one continuous thread. One continuous, devout thread. The earlier Rouvain reading is a bit more straightforward. Obviously the sound is different. The treble is smoother, the bass less pronounced, and more subtle tonal color can be easily divined. More important are the interpretive differences. Or similarities. Silverman plays in a similar way overall, but doesn’t achieve quite as much refinement and wholeness, if you will, as in the later recording. It’s a bit tauter and faster, with more and subtler coloring, and even more impressive diminuendo playing, at least in the opening movement. The second movement is more direct and has less contrast than the Orpheum recording. The final movement is again much the same, but it’s not as effective, or as devout. It’s still very good, though. But I prefer the Orpheum recording.
The 110 is likewise superb. Again starting with the Orpheum recording, it’s clear that Silverman knows this piece well and has devoted substantial time to his interpretation. Right from the get-go, Silverman extracts every last bit of transcendental goodness out of the simple yet profound Moderato cantabile molto espressivo. Every note, every dynamic shift, every everything is perfectly judged. Silverman dispenses with interpretive clutter and baggage and plays in an effortlessly ethereal way – he knows the music and is entirely comfortable with its soundworld and makes the listener equally comfortable. He’s not too soft, not too hard, not too fast, not too slow, not too anything. It’s superb. As good, and as well judged, is the vigorous Allegro molto. Take what I wrote about the opener and it applies here. But as with the other late sonatas, it is the last movement that matters most, and Silverman knows it. The Adagio ma non troppo is touching in its sparseness. The lonely contemplation, accentuated by the near silent pianissimos, and the unknowable questioning of the protagonist are quietly moving. It’s not sad or melancholy, it’s searching, desperately searching, and one wants to listen to every last bit of it. The first appearance of the fugue sounds like a sort of idealized, positive response to the imploring opening section, and it is meticulously delivered. Again, everything is judged just right. The return of the Adagio theme then becomes forlorn, exhausted, and inconsolable. Why go through it all again? The repeated chords that signal the transition back to the contrapuntal music are masterful. Silverman uses striking sforzandi and truncated decays followed by deftly deployed pauses for each chord, and he builds the volume up from quiet to very loud in perfect, almost theatrical increments. The inverts fugue and reversion to the original fugal material is tauter and faster than before and the work ends on a triumphant note. It’s an outstanding recording – one of the best I’ve heard. The Rouvain recording is also very good, but it’s not up to the Orpheum recording. The opening movement is more direct, with less dynamic gradation, but greater clarity. The second movement is faster, stronger, with some stomping playing. The final movement is drier, yet also sounds desolate and ethereal as appropriate. It’s not as searching and bleak in the slower sections, and the fugues are more direct, clearer, and faster, and not quite the same type of musical responses to the preceding material. The chord build up is more conventional, too. So, I must give the nod to the later recording.
As good as the preceding two works are, I wasn’t quite prepared for what Silverman does with the 111. His Orpheum recording is without question one of the finest I have ever heard and can be compared to anyone’s. I can think of none that are better. The only difference is in style and delivery, not quality. And that’s apparent from the start. The opening Maestoso opens in a sharp, striking manner, verging on outright fierceness. It is incredibly intense and dark, with unique and subtle variations in tone and beat. The second section starts with harsh, ferocious bass playing that quickly becomes thrilling, aggravated, fiery playing that is both frightening and growling. I use the word ‘frightening’ in an almost literal sense. For me that word can usually only be used in a figurative sense when applied to music. But here the playing is almost literally frightening at times. It is unyielding. But that’s not all there is. Silverman knows how and when to ease off, quickly and smoothly, to let all concerned rest – before attacking the piano again. As intense as the opening movement is, everything is perfectly judged with relation to everything else. How to top that? With an amazing second movement! The Arietta is quite firm, but still lovely, and it is immediately transcendental. The listener enters another world. That becomes more evident in the even more beautiful yet somewhat detached second half of the Arietta. The first variation marries both halves of the Arietta in a measured yet totally satisfying way. The second ratchets everything up a bit and reclaims just a taste of the urgency and intensity of the opener – but not even close to too much. The third variation is biting and quick and groovy, and the fourth and then the last two variations transform the work into the transcendental work of genius it is. The playing is gentler, the rubato at once more noticeable yet subtler, the effect more intimate. Time begins to melt away. The wonderful long trill, here sounding just a bit cutting and blurred – adds to a sense of moving further away from the crass material world and into a more wondrous realm. The piece concludes in glorious bliss. Since the Rouvain recordings of the 109 and 110 were not of the same quality as the Orpheum recordings, I assumed the same would be true here. I was partially correct. The Rouvain recording is not quite as good, but it is still superb and has its own formidable strengths. The opening movement is not as ferocious as the Orpheum recording, but it is still ominous. There is less contrast, too, as one would expect, but the playing is generally swifter and nimbler. Doesn’t sound especially impressive, huh? Well, the second movement is where the action is. The Arietta here is calmer, more serene, and more beautiful than in the later recording, especially in the first half. The second half sounds nearly static and truly sublime – among the most moving I’ve heard. The variations are less pronounced and contrasty, with the first two sounding more flowing, the second more tuneful, and the last variations lighter and smoother yet somehow nearly as transcendental. No, the Rouvain recording is not quite as good as the Orpheum recording, but it is still one of the better recordings I’ve heard of the piece. I guess if a pianist is really gonna nail one sonata, this is the one. Amazing.
Robert Silverman’s Orpheum cycle reinforces the reason why I keep buying complete cycles. I keep hoping to find that one (or more!) pianist who does everything right. Silverman pretty much does. He’s not in peak form for every sonata, but he’s always at least very good and interesting. At his formidable best he is much, much more than that. He’s got Beethoven in his blood; he loves the music and wants to share that with listeners. Of the twenty new cycles I’ve heard in the last twelve months, there is no doubt that Silverman is right up there among the very best. I’d put him in the top five, I guess. But he brings something unique to the music. He doesn’t grab hold of the listener, then manhandle and force the listener to hear things afresh in the way Friedrich Gulda does; he doesn’t play with utter indifference bordering on (utterly irresistible) musical nihilism in the same way that Wilhelm Backhaus does; he doesn’t beguile with trickery and an endless supply of nuance in the way that Eric Heidsieck does; and he doesn’t seduce the listener with ravishing tone and fluid grace the way Andrea Lucchesini does. No! He’s his own man. He’s sort of just out there, playing the music the way he sees fit. The listener must come to him. And when that happens, the listener will experience something unburdened by overanalyzation, excessive ego, or a need to impress. Silverman focuses on Beethoven. That’s the way it should be.
Posted on: 03 April 2006 by Oldnslow
I received the Silverman Beethoven set recently and have sampled a few of the sonatas. Very impressive indeed. I would characterize his approach in general as quite straightforward and self-effacing, with a wonderful ability to make sure the left hand parts are clearly and cleanly heard, no matter the tempo. In this he is no doubt helped by the Boesendorfer, but I noticed the same thing on a superb live recital which includes the Schuman Fantasy and Liszt Sonata, which I think was played on a Steinway. I do think the recording quality takes some getting used to--it is a rather recessed, large hall sound that I usually do not prefer. However, the ear quickly adjusts and I found it helps to keep the volume quite high. I think this is going to be a very fine set indeed, although I doubt it will supplant my favorites of Kempff, Fischer, and Gulda.
Posted on: 17 April 2006 by Oldnslow
Having listened to most of Silverman's Beethoven sonatas, I just thought I would weigh in briefly on the set. I concur with most of Todd's comments, and and very pleased with the set. And my ears have even come to enjoy the sound quality of the recording. Almost all of the sonatas are well played and thought out. Silverman for the most part offers restrained, but by no means boring, interpretations, a little like his idol Solomon--hardly a bad thing. Oddly enough, perhaps Soloman's greatest performance, the Hammerklavier, is one of Silverman's weakest--he just doesn't seem to be able to sustain the long lines required for this piece. In sum, I am very happy to have this set and suspect I shall return to it often. One interesting tidbit. According to Silverman's website, he recorded these performances under the influence of some kind of drug(prescribed) that he claims enhanced his performances, both technically and interpretivly. He now regrets using the drug and says he should have consulted his Dr. and postponed the sessions undtil he was off the drug. Well, this must be the wierdest revelation from a classical musician that I have ever heard. Reminds me of the stories about Horowitz performing drugged at one point in his career. I must say, if that were the standard used in jazz, we'd be missing a lot of classic recordings......
