Naim CD Players
Posted by: Ronnie on 21 March 2002
System old Linn Naim reference but still sounds good but have no CD player
Otherwise a CD3 or CD3.5 again check the the cd3 for wear although there is a lot less to go wrong in these. The 3.5 should be good for a long time as they arn't too old and you can also add a flatcap later which you can't on the other two.
CD2s pop up rarely but should be worthy of consideration.
CDX around the 1800 mark, if you can afford that then you should also look at everything else in the proice range.
Rega planets IMO look interesting, sound dull, with particular bass problems making it sound very digital indeed, just my opinion of course, but they are cheap I suppose.
Only if your like a more relaxed sound.
When I listen, I want a sense of real people playing real music on real instruments. The Genki sounds good, IMO, but it doesn't provide that sense of realness to me.
Smoothness is especially appealing when you listen to CDs, but smoothness palls eventually, when or if you realize there's somethingmissing.
Phil
My take on things is:-
CD3/3.5 - OK but pretty two-dimensional and lacking detail.
CDI/CD2 - I've had both and compared to their excellent successor the CDX, they're VERY two-dimensional, but have great rythmic drive.
CDX - Excellent, with an upgrade path.
CD5 - Superb v.f.m. and again upgradeable with a Flat-cap 2 etc: On a budget; I'd look for a s/h CD5 personally, or try to stretch to a CDX.
Be aware that an 'old' CD player (unlike an amplifier) can be very expensive to repair in the transport/laser dept:
Ian.
