Naim CD2
Posted by: jgeisen on 28 October 2001
I have a question or two about the my Naim CD2. I'm new to the forum so please be patient if I ask "dumb" (for you guys) questions. I've heard that there were two verions of the CD2 and that the transport is the main difference. Also, the later version sounds better. How do I determine if I have an earlier or later version? I currently am using the CD2 connected to a passive and then to my amp. Would hooking up the CD2 to a 52 preamp improve the sound over direct?
Thanks for your comments.
John Geisen
Posted on: 28 October 2001 by Dave Hartley
John,
I'm not familiar with the CD2 but I would have thought one option was to use the serial No
and then request an answer directly from Naim.
dave
Posted on: 28 October 2001 by jgeisen
Thanks Per. My SN is 120542. Not sure if that means that I have the 9 or 9Pro ?
John
