nap 150 upgrade to nap 250
Posted by: robertw on 02 November 2006
I have a nap 150/nap 175v cinema set up.Is it sensible to upgrade the 150 to a 250 power amp ,with a medium term view to upgrade the front L/R speakera.Presently I have B&W CM2s,AV2,DVD5....and a big plasma screen.I also listen to music and am thinking musically it would improve with a nap250.Am I right?
Posted on: 05 November 2006 by PJT
Yes a 250 will be brilliant for both music and HT, however you need to be able to power it with a *cap.
Pete
Posted on: 06 November 2006 by Adam Meredith
Originally posted by PJT:
.... however you need to be able to power it with a *cap.
Pete
This is not so. The Flat/HiCaps are used to power a non self-powered preamplifier NOT a power amplifier.
Therefore (the AV2 being self-powered) you can add the NAP 250 - no worries.
Posted on: 06 November 2006 by PJT
Pete
Duh !!! Brain Freeze Red Face
