Who's the idiot who designed the plastic CD case?
Posted by: waspus on 19 May 2006
I've lost my rag again!! And I'm sure that there must me many who do the same.
The plastic CD case design is utter c**p, such as :
- Look at it the wrong way and it breaks
- Looking at the sleeve notes is a dexterity test an when you do extract them a magnifying glass comes in very useful.
- picking up more than a couple at a time ends up with the centre ones shooting across the room
- A CD is ~1mm thick - we have a design that is 9mm thick - really helpful for storing
- the centre locating crown either breaks or tries to tempt CD breakage
- stack more than a few on to of each other and any draft from a door or window will blow them over
How can someone design something so awful?
Does anybody know the culprit so I can redirect the venom of som Animal Rights Activists to his door 0r worse send him our cd case casualties??
Posted on: 19 May 2006 by JonR
Whoever it is presumably now runs a fairly lucrative business supplying all those replacement CD cases you can buy...
Posted on: 19 May 2006 by 7V
I prefer the typical DVD case design. They could use that.
Posted on: 19 May 2006 by erik scothron
It was designed by the man who formerly had to make cases by carving them out of wood.
Posted on: 19 May 2006 by NaimDropper
Should be drawn and quartered.
Posted on: 19 May 2006 by Guido Fawkes
I'm glad I'm not the only one who dislikes CD plastic cases. They are really cheap and tacky.
BTW who thought putting an ugly great bar code on the artwork was a good idea? Applies to vinyl too.
Posted on: 19 May 2006 by Nigel Cavendish
OK waspus, what do you suggest?
I have no problem with CD cases - once I've got the wrapper off.
Posted on: 19 May 2006 by JamieWednesday
SACD cases seem much more substantial. Still small though. I suppose you could buy box sets.
Personally, I don't keep the cases on CDs anymore as I've run out of room, I store the CD and the inserts in slip in/out carry cases like wot they bring to the HiFi shows innit. Plenty on ebay.
Posted on: 19 May 2006 by Steve O
As crap as they are, and believe me I do agree they are crap, they are still better than those LP type cardboard efforts. How cheap and nasty are they?
I can never get the bloody CD out!
Posted on: 19 May 2006 by Simon Perry
Its our punishment for abandoning vinyl. We get what we deserve.
Posted on: 19 May 2006 by Milo Tweenie
Slight hijack, but can anyone suggest a source of decent quality replacement cases (particularly doubles with the fold out gate)?
I've bought from Townsend Records before, but the cases they supply are lighter weight than originals and break much more easily. Cheap, but I'd rather a higher quality product.
Many thanks.
Posted on: 19 May 2006 by graham55
Silly comment, in my opinion. As frustrating as CD cases can be, only a loony would go back to the cardboard, paper and plastic that 'protected' LPs.
Posted on: 19 May 2006 by u5227470736789439
Many thanks.
I have bought many from Concorde Stationary in Worcester.
I guess any reasonable stationary emporium would have them. Many computer data disc come on a spool and some of these discs will need decent housing when finished.
Fredrik
Posted on: 19 May 2006 by gusi
I think that in the 80's cd cases looked very modern and much smaller than cassettes and vinyl.
The double cd cases were a bit of a disaster though. I quite like the thin cases you get for compuer cd now though.
I am not a fan at all of the dvd cases - way to big. If you have a few hundred they dominate a room. I guess they have to be bigger to reflect the perceived value. I wonder how big HD DVD cases will be.
Gus
Posted on: 20 May 2006 by 7V
Call me a loony. LP covers had other functions too - as far as I can remember. Cool
Posted on: 20 May 2006 by BigH47
SVP
They have loads of CD/DVD cases up to 8 way for DVD. See under cases and storage.
Posted on: 20 May 2006 by u5227470736789439
Dear 7V,
I am not calling you anything, but I have no idea what use an LP sleeve might be put to except housing an LP!
LP sleeves often seemed designed specifically to warp or scratch their very fragile contents.
Gatefold covers were always useless with respect to warping and often even quite important recordings came with plain paper envelopes, where any movement of the vinyl in the sleeve more or guaranteed surface damage, and how often that occured before the first playing!
The only disagvantage of the CD (either sonically or as an object) is the microscopic size of the print in any notes, which have to be paired down to the size of the jewel case. Given the decreasingly quality of these notes compared to those issued with LPs and more specifically 78 albums, this reduces the importance of the size of the print used!
One gripe I have is the occasional need to entirely remove the notes to find the tracking details. These should be printed on the back cover, and again in the largest feasable print on the back of the booklet so as to be visible when the CD case is open...
Fredrik
I use the thin (4mm) cases for CDRs and DVDRs.£1 for 10 in Poundland. Being so thin labelling is the problem(that's why CD cases are 10mmm I suggest). They are fragile though but cheap.
Howard
Dear Howard,
I find that the adhesive labels such as you might use for addressing an envelope are perfect, as you rarely need more information than title, and a few tracking cues. They stick on the outside, and are not visble once the cover is stored on a shelf, or whatever...
Fredrik
Fredrik
I like to have the labels on the spine if possible. I usually write on the spine with a CD pen. I use record collector so even if I can't see the labels its only one small (IKEA Benno) shelf to search.
Howard
Posted on: 20 May 2006 by Simon Perry
ah, call me a loony then.
Posted on: 20 May 2006 by Tam
Dear Fredrik,
Be thankful you don't own my copy of the OED - with its micrographically reduced pages a magnifying glass is obligatory.
regards, Tam
Dear Tam,
It is alright. On times I struggle to read the track numbers. It must be comical to watch me count them down!
Fredrik
Posted on: 21 May 2006 by David Leedham
"I have no problem with CD cases - once I've got the wrapper off."
This is where it starts for me too. perhaps I`m just too exited to get listen, but these wraps are frustrating, asmall rip strip would be a blessing.
The centre "wheel" attatchment fractures into small peices on me 1 in 10 cases!
The science of modern materials has an answer!
Posted on: 21 May 2006 by JamieWednesday
How about the US style ones which have the sticker wrapped over the top too. Invariably impossible to get off in one go and witout leaving the sticky residue either. What Bastards.
Posted on: 21 May 2006 by gusi
Too right! nothing worse than having to fight your way through 3 layers of plastic (including the annoying sticker seal accross the top).
Another pet hate is the super sticky discount and nice price stickers that are impossible to remove cleanly.
Fortunately the old double cd cases have been scrapped.
