Weiss , Amarra and Me .
Posted by: AS332 on 12 December 2009
First of all , thank you to all the forum members who have offered their advice over the last few days on the other thread , I decided to start a new thread to let you know how I have been getting on .
At the beginning of the week as the Weiss arrived I had worrying thoughts about how I would sell my lavry and is it wise to be forking out in the region of £2000 just before Christmas . Here we are at the end of the week and the Weiss and the Amarra software are back in the box wrapped up ready to be shipped back to Purite !
Unfortunately as far as the Amarra / Amarra Mini software was concerned , in my system I just could not tell any difference at all .
The annoying thing is that I really wanted to .
First off with the Lavry and then with the Weiss , I played whole tracks , turned the software on and off during tracks , reinstalled the software and even moved the dongle about !
If anyone has any ideas I would be interested to hear them . Maybe I'm just a bit odd .
On to the Weiss DAC2 , lovely bit of kit . Good full and rich sound and very easy to listen to. The only problem is that it is £1800 and as good as it is , and it is good , to me it just highlighted how good the Lavry is for the money.
The lavry has been plugged back in since last night and the sound is fantastic . If the Weiss had been £1000 then I would have had no doubts but in the end I'm still a Yorkshireman and it's a lot of cash .
A couple of hours a Friend brought round a Power-Line and that has made a difference to the sound , I don't think he is getting it back!
Anyway , that is just my own opinion on my system but an interesting week .
Ed
Posted on: 12 December 2009 by paremus
Ed,
Which version of Amarra were you trying out? The new beta is much better than the current release - which is generally felt to be a step back from the previous release. HAve a chat with your dealer.
Also try out the HiFace / USB to SPDIF with the Lavry - I'm really taken with what this little box does with a Mac Mini.
Richard
Posted on: 12 December 2009 by AS332
Hi Richard ,
I was sent the latest beta yesterday to try and so far no real difference , very odd . I will try again later when CBBC is not blaring out of the TV !
I came across the HiFace yesterday for the first time and will ask Keith @ Purite about it , it does look interesting .
Ed
Posted on: 12 December 2009 by js
Did you try some AIFF files to be certain the Amarra was in effect and decoding not in the mix? Did you try the dig out of the Weiss into the Lavry set to narrow?
Posted on: 13 December 2009 by Former member
I didnt think Amarra worked on the Lavry DA-10.
Posted on: 13 December 2009 by paremus
because?
I was told this was the case by James,It works with the Weiss though.
Posted on: 13 December 2009 by js
needs an interface beyond core audio as in dig out from Weiss/TC/HiFace/M-audio/lynx. I think you may have just misunderstood James' meaning.
When i tried it on my Lavry it would not work.
Posted on: 13 December 2009 by james n
Amarra works with certain approved interfaces - if the Lavry is running through the Mac toslink output then it wont make much (if any) difference.
Ed, Shame you didnt like the Weiss over the Lavry. I found them both quite similar via toslink, the Weiss coming into its own via Firewire. I'm suprised you didnt hear any difference between Amarra on and off. Did you see the level meters running whilst it was playing a track. Just one more thing - what cables did you use. I got a phone call from Keith earlier in the week about a customer of his who was having trouble connecting a DAC2 into a Naim preamp. The Lavry is very good though and a good match to a Naim system.
James
Posted on: 13 December 2009 by Joe Bibb
Hi Ed,
I'm not clear whether you were using the Firewire interface with the Weiss? Like James, I didn't think there was much in it using optical but the Firewire was a different matter.
The Lavry remains stunning value though, for sure.
Joe
Posted on: 13 December 2009 by AS332
Hi all ,
I did like the Weiss , however I felt that for me the improvement was not big enough to justify spending £1800 on the Weiss and sell the Lavry . The Lavry held up very well indeed .
Joe / James , I used A Belkin 9pin / 6 Pin Firewire between the mini and the Weiss and the Chord Chameleon XLR to din cable to my 252 that I use for my Lavry .
As far as the Amarra software is concerned , I really wanted to hear a difference but didn't .
I have no idea why . I even contacted Sonic Studio but the guy I spoke to didn't know much about Amarra and the man who does , Jon , has not replied to my emails yet .
I may try the HiFace to see what that does rather than the digital out on the Mini.
Ed
Ed,
The XLR outputs on the Weiss are balanced - the 252 is not. Unlike the Lavry, I don't think you can change them. I would try the Weiss RCA outputs for connection to the 252.
Joe
Ahh . This could be your classic schoolboy error.
Somewhere hiding in the Cupboard I have an old RCA to din cable I could try . Worth a crack .
Ed
It should be fine. 1 leg of a balanced out is perfectly acceptable single ended output into a 252. That wasn't it unless the added circuitry for the balanced out is the issue or the configuration was wrong for this aparticular output. generally it's pin 2 hot. pin 1 gnd and pin 3 open. Sometimes pin 3 needs to be grounded but very unlikely here for the configuraion or the cable.
Posted on: 14 December 2009 by PMR
James
Hi James, did you ever compare the Weiss using CD Transport/SPDIF Coaxial vs. MAC/Firewire?
Peter
Posted on: 15 December 2009 by paremus
Folks
Clarification from Sonic Studios. Amarra with Mac > optical out to DAC works.
Now whether there is a discernible difference in this configuration is another question. For example I felt there was in my system (by no means obvious) - but could tell no difference with Lavry in narrow/Xtal.
Now with the HiFace / Coax in mix the difference is more significant and I also have a clear preference for the Lavry in narrow.
Ed interested in your thoughts if you give it another go.
Richard
Posted on: 15 December 2009 by AS332
Richard ,
I think I will try the HiFace . Thanks for the clarification from Sonic Studio .
I'm sending the DAC2 back today to Purite as I don't have the time to do any more testing before Christmas . ( Oil Rig workers insist on being flown home for the holidays ) !
I will try out Amarra with the HiFace when possible .
Ed
Posted on: 15 December 2009 by js
Originally posted by paremus:
Folks
Richard
Man, I wish there were posts like this about a year ago when I was speaking about the limits of computer OS/TOS and crystal setting and getting ripped a new one for it by owners that knew it was bit perfect.
I recall everyone ripping the way the dem was done because they didn't like the result yet in our setup and more informative sources we could clearly hear the dif between narrow and crystal. Hmmm. Always room for difference of opinion(unless mine
) but we obviously weren't compromised. Nice to see us all coming together on what sorts of things work regardless of preferences.
Posted on: 16 December 2009 by AS332
A HiFace to try out has just arrived and just waiting for a coax cable to put it with .
Ed
Posted on: 16 December 2009 by paremus
JS
I was waiting for this
My stance was and still is that IMO the Lavry / MAC is preferable to my CDSII - which I still own (its like a classic car). I don't think I claimed anything else - but the threads have been lost :-/
IMO with the HiFace - Coax is clearly better than optical and I concur narrow is better. So your were right on these points IMO.
But this just reinforces my view w.r.t. the Lavry - and widens the gap w.r.t my CDSII!
I'm hoping to listen to the NAIM DAC real soon. I'm hoping my front end configuration into the NAIM DAC will make it fly. But as always I'll go in with an open mind.
Richard
Posted on: 16 December 2009 by js
No problem and the preference is your own and accepted. I also don't recall most of those that rose up against me or if you had unkind words. I'm just happy to see these types of posts and the response wasn't directed at you personally.
It's was the dismisal of my observations, opinion and competance being called to question (because everything was bit perfect
) that I was referring to when I came up with the same obsevation as you just did. I don't expect us to like the same things but it's great if we can agree to approach this from the same direction. Though not everyone here agrees, many have moved away from Itunes, tos, OS mixers and stock rips. You preferred it to a CDP with the original configuration and I didn't. No problem there. Agreement was never a requirement. I said at the time that we would all eventually grow closer on this as it seemed apparent to me that most would hear the basic configuration stuff eventually. It may not guide an absolute preference of kit as we don't all like the same things but most will appreciate a better stream when properly presented with it.
JS,
Totally agree. Difference in preferences is absolutely fine. Unfortunately it frequently tends to polarise and morph into statements about 'absolutes'.
Richard
Some things are just a better way but it doesn't necessarily equate to better in a given circuit as there are always other factors also influencing a setup. This however, isn't shooting blind but end result is what ultimately matters.
Posted on: 22 December 2009 by AS332
I have been trying out the HiFace for the last few days and it is a great little piece of kit .
However , when I stopped listening for a while and then went back to listen again there was no sound .
So I sent a email to M2Tech and they replied very quickly with a thought that it may be a problem with power saving and USB suspend and they would work on a new driver for Macs.
Hey presto , two days later a new driver is issued and the problem has gone . Great customer service and the demo continues .
Ed
Posted on: 22 December 2009 by kent
Richard
May I ask in what areas does the Lavry / MAC is preferable to CDSII?
