CD 3.5 keep skipping
Posted by: Kevin Loo on 26 June 2003
I recently got a second hand 3.5. It is very choosy and it always skips, even with Naim CDs. Sometimes, it will even stop playing with 'Err' appearing on screen. May I know what causes this? Thanks all.
Posted on: 26 June 2003 by Markus
Kevin,
Can you obtain a replacement puck? The symptoms you describe could be due to a worn puck and that is where I would start...
Markus
